Most of you should know by now that I am heavily into restoring and refurbishing Honda Sprees. So I figured I would share a few restoring projects that I'm currently working on. Both are 1984 White Sprees. Both terribly deteriorating and rusting very badly. And both are from different sides of the USA. Once they arrived at Spree headquarters I got to work taking pictures and reviewing the damage and all that. The first one has severe rust damage to the rims, muffler, and engine. And with that being said the rear wheel was corroded and rusted so bad the transmission was locked right up with the wheel and unfortunately the motor was not salvageable.
(2) 1984 White Spree's Restoration
Hello all!
No biggie, I just rebuilt an 84-85 motor I had saved and will make a perfect back-up.
The second one, not as bad as the first one, motor was stuck but got it freed up with some WD-40, tranny spins smoothly, looks like it can be saved.
- IMG_0070.JPG (120.69 KiB) Viewed 20466 times
- IMG_0030.JPG (123.83 KiB) Viewed 20466 times
Re: (2) 84 Spree's Restoration
Here's an under the hood pic of the first one, it's terrible. Guess it sat in the guys backyard for....20 years.....
- IMG_0094.JPG (150.38 KiB) Viewed 20465 times
And the second one
- IMG_0041.JPG (156.68 KiB) Viewed 20465 times
Here we go, tear down in progress...
- IMG_0141.JPG (165.06 KiB) Viewed 20465 times
- IMG_0138.JPG (156.75 KiB) Viewed 20465 times
Getting the plastics gathered and cleaned to prepare for repainting.
- IMG_0139.JPG (129.79 KiB) Viewed 20465 times
- IMG_0140.JPG (140.2 KiB) Viewed 20465 times
Today's the day! Time to get some paint on these! (After all the cleaning, sanding, and pre-cleaning of course)
- IMG_0165.JPG (126.87 KiB) Viewed 20464 times
- IMG_0175.JPG (90.75 KiB) Viewed 20464 times
- IMG_0179.JPG (80.78 KiB) Viewed 20464 times
And finally, I'll be dropping these frames off Monday to be blasted, and will be picking the plastics up afterwards.
- IMG_0133.JPG (125.68 KiB) Viewed 20464 times
- IMG_0132.JPG (126.56 KiB) Viewed 20464 times
- R1Titan911
Wow Jerz finally something new, RESTO SPREE! JK. Your rebuilds are 2nd to non sir. Good stuff
87' Spree: "Victoria's Spreecret"
78' Express:
78' Express:
R1Titan911 wrote:Wow Jerz finally something new, RESTO SPREE! JK. Your rebuilds are 2nd to non sir. Good stuff
Im sure your spare parts bin is extensive from all these restorations but if you need something random you don't have, Im sure the HS community would be happy to provide. I, for one, have plenty of random Spree doo-dads collecting dust. Good job on bringing these bad boys back from the dead, jerz!
Thanks man! I'll for sure let you know! Also I am considering that 85 spree spare motor you have if it's still available?Meatball wrote:Im sure your spare parts bin is extensive from all these restorations but if you need something random you don't have, Im sure the HS community would be happy to provide. I, for one, have plenty of random Spree doo-dads collecting dust. Good job on bringing these bad boys back from the dead, jerz!
Yup, still here. Has TAZ gears in it and a plug in the oil pump hole. OEM oil pump and gears will be included.
Definetly want it! PM me the details and pricing.Meatball wrote:Yup, still here. Has TAZ gears in it and a plug in the oil pump hole. OEM oil pump and gears will be included.
Plastics are done and they turned out amazing. These are gonna be two nice sprees when I'm done shortly.
- IMG_0255.JPG (112.17 KiB) Viewed 20389 times
- IMG_0258.JPG (103.1 KiB) Viewed 20389 times
- IMG_0262.JPG (99.1 KiB) Viewed 20389 times
Started to put some of the decals on.
- IMG_0263.JPG (106.23 KiB) Viewed 20388 times
- IMG_0265.JPG (87.83 KiB) Viewed 20388 times
