My 1994 Honda Elite
Re: My 1994 Honda Elite
You have to play around with the rollers you put in there. Typically you get more top end with heavier rollers and more acceleration with lighter ones. I run 5.5 g in mine and I'm still messing with it. Just something you have to get dialed in. I would also grab a set of gears from SSS, the 9:1 or even 8.44 gears are a great combo with the vari. Most people do that when they are just getting their feet wet into performance mods. You should see high 40s, low 50s on gears and a variator with the right tune.
Will an aftermarket air intake increase performance? Also are aftermarket CDIs good for a stock build?
Currently own:
->1995 Honda Elite 50 (Derestricted)
Have previously owned:
->Multiple 94-01 Elite 50s
->1985 and 1986 Honda Sprees
->1985 Honda Aero 50
- Xxbeejay45xx
Air intake will need to be rejetted and you don't need a aftermarket Cdi but if you choose to get one... Malossi is the one I have
95 Elite SR af16e
72cc Polini Corsa
28 Oko Carb 58/144
Ported intake
ZX Trans
Polini vari, clutch, springs
5.5 rollers
Malossi crank , CDI
Genuine Arrow pipe
Front and Rear disc brakes
Dio Live headset
Stretch and fatty rear wheel
72cc Polini Corsa
28 Oko Carb 58/144
Ported intake
ZX Trans
5.5 rollers
Malossi crank , CDI
Genuine Arrow pipe
Dio Live headset
Decided to get a GPS app to see what my top end actually is since I can't tell on the speedometer. Is this pretty good for the stuff I've done to my elite?
- Screenshot_20170915-171151-720x785-540x589.png (49.46 KiB) Viewed 11712 times
Currently own:
Made a video showing my top speed. I know it's not as fast as other builds, but it's a lot faster than stock!
https://www.youtube.com/watch?v=OGuK9bAFJkE
Currently own:
Made another quick video showing what the PG Short exhaust is like on an elite for people interested.
https://www.youtube.com/watch?v=smi1_QngeOw
Currently own:
Got the 15x42 (9:8:1) gears installed today. Noticed a decrease in acceleration which I expected. Top end was pretty good. Still have to check the gps, but the needle seemed to go farther than usual!
Currently own:
Dude, sounds like you need to up jet.ansneds wrote:Got the 15x42 (9:8:1) gears installed today. Noticed a decrease in acceleration which I expected. Top end was pretty good. Still have to check the gps, but the needle seemed to go farther than usual!
I think I do, still running 78 main. What would you recommend going up to?
Currently own:
Big thanks to bfowler for the tail light and turn signal lenses!
- IMG_20171102_170407344-1024x576.jpg (163.8 KiB) Viewed 11492 times
- IMG_20171102_170430796-1024x576.jpg (190.4 KiB) Viewed 11492 times
Currently own:
