Best 2T Oil??
Dallen70
Best 2T Oil??
Post by Dallen70 »
Been asking around about the best 2t oil I should use for premix in my Elite. Using Klotz benol castor oil right now. Looking to transition to a good high end synthetic 2t oil. Not as high end as red line but just seeing what all you guys recommend and what y'all use, thanks
bonesv
Re: Best 2T Oil??
Post by bonesv »
I use Klotz full synth with all bbk's and this question has been asked many times so you can use the search feature to find past and more recent opinions to compare with. I believe the real answer is whatever suits your particular purpose/setup the best.
Meatball
Re: Best 2T Oil??
Post by Meatball »
I use Maxima Pro but as Bones suggested...its a matter of opinion. Some people swear by Brand X or Brand Y but one things for sure, the oils today are far superior to what was available when these scooters were made and have been running on for many years. So whichever you choose, it will be a vast improvement to what the bike has ever seen its entire life.
Just be aware that some synthetic 2T oils are not recommended for oil injection systems (if youre using the pump). For example: Royal Purple claims its 2T oil is pre-mix only. Others may as well.
Its also been discussed that using high-end synthetic for a freshly built motor will prolong the break-in process due to its low friction capabilities. Some suggest running a few tanks of quality conventional oil to seat the rings and then switch to synthetic of choice. Again, this is an opinion that has been argued about by the masses and depends on who you ask. Some swear by it while others think its bologna.
R1Titan911
Re: Best 2T Oil??
Post by R1Titan911 »
Amsoil Dominator!
eclark5483
Re: Best 2T Oil??
Post by eclark5483 »
Pro Honda GN2 injector oil. The only brand approved by Honda for their engines.
jakubman1
Re: Best 2T Oil??
Post by jakubman1 »
Castro 927
benji
Re: Best 2T Oil??
Post by benji »
Evoo
(Extra Virgin Olive Oil)
Jk
Dallen70
Re: Best 2T Oil??
Post by Dallen70 »
Lmaaao
burnt_toast
Re: Best 2T Oil??
Post by burnt_toast »
Castor927 for premix. Hands down
Smells great and runs even better.
http://www.oneillbrothers.com/blog/oil/
projects galore :nerd:
Dallen70
Re: Best 2T Oil??
Post by Dallen70 »
Trying to switch from castor
burnt_toast
Re: Best 2T Oil??
but why?
benji
Re: Best 2T Oil??
Post by benji »
Expense maybe? Castor ain't cheap
MrJumps
Re: Best 2T Oil??
Post by MrJumps »
mortul or sum shiet
2021 DRZ400sm :worship:
burnt_toast
Re: Best 2T Oil??
benji wrote:Expense maybe? Castor ain't cheap
Yeah, but he asked for the "Best" High-end oil he can use. And I stand by Castor927, have gotten some wicked performance along with it.
Plus if he's switching from castor. Klotz benol castor oil and Castor927 are something TOTALLY different.
OP, click the link I posted in previous thread and see the difference between the two, then conclude which is better :wink:
Dallen70
Re: Best 2T Oil??
Post by Dallen70 »
Yeah klotz is good stuff, I'm thinking about using red line but it's darn expensive
