Polini on stock motor?
Cody99
Post by Cody99 »
Anyone just upgraded to a polini that doesn't have a bbk? I'd like to kick the keihin to the curb, just wanna know what people have run and had good luck with. Any advice or input greatly appreciated.
eclark5483
Re: Polini on stock motor?
Post by eclark5483 »
Biggest carb you wanna go on a Spree block is 17.5mm. A Polini would be good, Mikuni, delLorton would also work. All you need is the adapter and new throttle cable. Check your clearance from the shock.
Cody99
Post by Cody99 »
Alright thanks. I was looking at the 17mm just wasn't sure if you could make the throttle cable work or if it was easier to just run the new one. What would be a comparable main jet from the stock 68 to the polini size? Thanks for the quick response just sitting in the garage and tinkering with some ideas!!!
Meatball
Post by Meatball »
Cody99 wrote:Anyone just upgraded to a polini that doesn't have a bbk?
Whats the point in doing this? The only gain you'll see is from the weight reduction of your wallet.
eclark5483
Cody99 wrote:Alright thanks. I was looking at the 17mm just wasn't sure if you could make the throttle cable work or if it was easier to just run the new one. What would be a comparable main jet from the stock 68 to the polini size? Thanks for the quick response just sitting in the garage and tinkering with some ideas!!!
Polini comes with a 38 pilot and 80 main. And like meatball said.. what would be the point?
Cody99
Post by Cody99 »
I'll pass on it then just thought it would be a little better than the stock one. I'll wait till I wanna do the bbk to dive into that. Thanks for the advice.
eclark5483
K, cool man. And (if) when you do decide to do a BBK, don't hesitate to ask for guidance and plenty of topics covering it. How bout some pics?? :peace:
