Alternative Ruckus Variator
ck_ni
Post by ck_ni »
What other Variators fit into a NB50 AF05E?
I know Ruckus ones can fit, but finding a stock one in the UK is few and far between.
Are there any other variators that fit, I see performance ones for Peugeot ST from poland and france...anyone ever used one of these?
Dont want to go down the rot of engines mods, but a more usable variator / slightly better top speed would be great.
Meatball
Re: Alternative Ruckus Variator
Post by Meatball »
If you want "better top speed" than stock, you must go aftermarket. There are a few vari's from other models that fit but would give you the same performance as the stock one you have.
There are a few different brands and they can be purchased at a few different places but heres one option... https://scooterswapshop.com/products/se ... i-variator
In 2008-09, a member called Scooterwerx posted good results with a stock Ruckus variator. It's larger in diameter than the stocker, enough to make a difference in top speed if the power (or a stiff tailwind) is there. His modified Aero went well over 40 with "Wheelies everywhere". There is a possibility that the stock belt may be too short, and go "too low" on the rear pulley. If it's short enough to jam, it might break. Malossi made a "special" belt for S and 05 transmissions that was a few mm longer, probably for that reason. I'm not sure if it's still available.
benji
Post by benji »
Most stuff for an af18 should fit. You might have to use your factory boss tho. Af16 stuff is a different size I think.
