another 50x50=98cc for a friend. random photos.
Re: another 50x50=98cc for a friend. random photos.
- 20170603_074307.jpg (151.69 KiB) Viewed 7355 times
Nice Job Ped, as usual! You bring it to us in full color! Are you using a specific boring tool on all of it? Also, which pipe is best suited to use for this cylinder? Thanks for the pics!
Hi bones. Thanks. I use a homemade Dremel head, and a drill press. Also a Crosscut porting bit.
That ugly looking, really doesn't fit right, polini race pipe from SSS works great on 98cc. Top speed on my 98cc Speedio 74 mph with that pipe.
There's so many different setups and pipes they all work great.
The 50mm has good power. will work great with stock stroke too.
Very nice work, but you didn't use the die-grinder for the cases, did you?
[quote=-111"]Greetings:
Very nice work, but you didn't use the die-grinder for the cases, did you?[/quote]
Hi wheelman. Its precise hand Dremel work, same as porting a head.
I do use a drill press, motor has to be level. Most is hand work.
- 20170604_033115.jpg (160.31 KiB) Viewed 7325 times
- 20170603_204923.jpg (156.32 KiB) Viewed 7332 times
- 20170603_205047.jpg (151.13 KiB) Viewed 7332 times
- 20170604_051329.jpg (137.49 KiB) Viewed 7325 times
- 20170604_054626.jpg (160.34 KiB) Viewed 7325 times
- 20170604_035314.jpg (139.21 KiB) Viewed 7325 times
- 20170604_054817.jpg (170.2 KiB) Viewed 7325 times
- 20170604_054843.jpg (148.77 KiB) Viewed 7325 times
- 20170604_053952.jpg (143.11 KiB) Viewed 7325 times
- 20170604_062043.jpg (165.48 KiB) Viewed 7325 times
Hi meatball. I have a friend who has one but. I've never tried one.Meatball wrote:Anyone ever try one of these? Results?
http://www.ebay.com/itm/Honda-Dio-Elite ... 1889413556
- 20170606_030200.jpg (125.43 KiB) Viewed 7315 times
- 20170606_015545.jpg (139.95 KiB) Viewed 7315 times
- 20170609_214729.jpg (200.15 KiB) Viewed 7286 times
- 20170609_214747.jpg (185.45 KiB) Viewed 7286 times
- 20170609_214805.jpg (190.67 KiB) Viewed 7286 times
