What brand.
Looking for ideas for a nice carb setup. 1/4 throttle to 3/4 throttle is no good on my 28mm oko.
Full throttle works great
The pilot can be changed on the JDM AF18 Dio carbs. However, you can get a better aftermarket carb for the same price you'll pay. On the other hand, using the JDM carb gives you the option to run the corresponding throttle cable, airbox, intake, reeds etc....but if youre planning on using all stock parts, would you really need to change the pilot then?Trafficjamz wrote:Can the pilot jet be changed in a jdm zx dio carb?
