54mm build/ nuts packed in box
Re: 54mm / nuts packed in box
Change in plan forum. going with the 54mm liquid cool Big Bore Kit.
- 20170808_003912.jpg (198.81 KiB) Viewed 19401 times
Put on a pot of coffee...the way its going, you'll fire that thing by morning! Youre flying!
Forum this is going to be a 120 CC liquid cooled motor.
Picked up the water cool cylinder from scooterswapshop they have them
- 20170808_003912.jpg (198.81 KiB) Viewed 19402 times
- 20170808_004107.jpg (178.95 KiB) Viewed 19402 times
- 20170808_004325.jpg (177.46 KiB) Viewed 19402 times
- 20170808_004635.jpg (183.04 KiB) Viewed 19402 times
- 20170808_004551.jpg (122.7 KiB) Viewed 19402 times
- 20170808_004413.jpg (184.25 KiB) Viewed 19402 times
Meatball wrote:Put on a pot of coffee...the way its going, you'll fire that thing by morning! Youre flying!
Re: 54mm build/ nuts packed in box
Forum, You can drill, and put a bolt right through left side holes.
I drilled and tapped the hole. I used a smaller drill bit so not to cut the threads.
Forum, change in plan. I just drill straight through makes life easier.
- 20170809_031544.jpg (135.82 KiB) Viewed 19392 times
- 20170809_031426.jpg (127.54 KiB) Viewed 19392 times
- 20170809_030433.jpg (177.3 KiB) Viewed 19393 times
I used this Dremel tip to flatten the surface so I can add a lock nut.
- 20170809_032729.jpg (171.2 KiB) Viewed 19392 times
- 20170809_032822.jpg (176.42 KiB) Viewed 19392 times
- 20170809_034332.jpg (158.19 KiB) Viewed 19392 times
The tap is M6-1.0 .
- 20170809_034415.jpg (159.64 KiB) Viewed 19391 times
- 20170809_035113.jpg (164.04 KiB) Viewed 19391 times
- 20170809_035532.jpg (181.65 KiB) Viewed 19391 times
I'm going to make the clearances for the ZX Drive Variator. I'm also going to smooth the small bump in the back. rubs on the belt.
- 20170809_035656.jpg (160.32 KiB) Viewed 19390 times
- 20170809_043957.jpg (164.53 KiB) Viewed 19390 times
- 20170809_044019.jpg (180.17 KiB) Viewed 19390 times
- 20170809_045047.jpg (171.58 KiB) Viewed 19389 times
- 20170809_045004.jpg (188.34 KiB) Viewed 19389 times
- 20170809_054144.jpg (156.23 KiB) Viewed 19389 times
I'm going to use J-B Weld on the thin case. To add thickness to the case, For sealing purposes.
J-B Weld, and Wax paper.
Forum, not my video. But for information on J-B weld strength.
The Ultimate Epoxy Competition--Which Epoxy is the Best? video https://www.youtube.com/watch?v=XObmZIbHOzY
- 20170809_054738.jpg (156.29 KiB) Viewed 19388 times
- 20170809_060808.jpg (156.1 KiB) Viewed 19388 times
I've used J-B Weld for sealing on one of my other Motors. been on there 3 years no problem.
Before I put it together . It takes 24 hours for this extra meat to dry.
- 20170809_073549.jpg (136.36 KiB) Viewed 19384 times
- 20170809_100811.jpg (120.08 KiB) Viewed 19384 times
- 20170809_100940.jpg (168.84 KiB) Viewed 19384 times
hi forum.
I've cut almost all internal walls inside the motor.
more photos.
Forum, hopefully someone can make a bigger after-market case? there is no room in stock cases.
- 20170810_023628.jpg (162.35 KiB) Viewed 19371 times
- 20170810_023759.jpg (176.87 KiB) Viewed 19371 times
- 20170810_024408.jpg (150.06 KiB) Viewed 19371 times
More photos.
- 20170810_024607.jpg (142.68 KiB) Viewed 19371 times
- 20170810_025326.jpg (105.23 KiB) Viewed 19371 times
- 20170810_030823.jpg (173.54 KiB) Viewed 19371 times
- 20170810_031917.jpg (176.34 KiB) Viewed 19371 times
- 20170810_032148.jpg (169.46 KiB) Viewed 19371 times
