54mm build/ nuts packed in box
Re: 54mm build/ nuts packed in box
- 20170810_032324.jpg (149.65 KiB) Viewed 24441 times
This is the best build to come along in a looong time. Looks great, ped!
Thanks meatball it's coming together. The reason you don't see many build's it's because everyone's riding. Hehe.Meatball wrote:This is the best build to come along in a looong time. Looks great, ped!![]()
- 20170819_002514.jpg (158.84 KiB) Viewed 24406 times
- 20170819_010525.jpg (175.52 KiB) Viewed 24406 times
- 20170819_031224.jpg (142.5 KiB) Viewed 24406 times
- 20170819_031342.jpg (160.93 KiB) Viewed 24406 times
- 20170819_030934.jpg (163.84 KiB) Viewed 24406 times
- 20170819_031201.jpg (154.24 KiB) Viewed 24406 times
- 20170819_030955.jpg (150.57 KiB) Viewed 24406 times
- 20170819_033826.jpg (172.27 KiB) Viewed 24406 times
there are special "slim" crankshaft bearings that are used with this crank.
if you use the stock bearings the case will not close and seal together.
i have slim bearings for sale if you need a set.
lmk
btw nice build very meticulous very nice
lmk
Re: 54mm / nuts packed in box
ped wrote:
Where did you get that cutting tool?
Revolutionary
- Goped
Cool build!
Thanks. The Kit came with the bearings.HI808SYM wrote:there are special "slim" crankshaft bearings that are used with this crank.
lmk
http://www.ebay.com/itm/Honda-Dio-Elite ... SwSlBYucVtwwolvert wrote:ped wrote:
Hi, I bought the tool on eBay. It's very hard to work with this tool. You have to take off very light cuts. You also have to use a Dremel to finish. There is some skill involved. I recommend a machine shop. The tolerance are too close and easy to screw up. Also it's not easy to cut the top of case for the Big Bore cylinder. Good luck
Thanks Rev.Revolutionary wrote:Cool build!
- 20170821_013835.jpg (133.89 KiB) Viewed 24331 times
- 20170821_015140.jpg (136 KiB) Viewed 24331 times
- 20170821_023546.jpg (130.6 KiB) Viewed 24331 times
Hi Forum. The water cooled motor is on hold. I'll add the air cool photos, which is the same 54mm build.
- 20170830_025926.jpg (171.62 KiB) Viewed 24331 times
- 20170830_030607.jpg (142.78 KiB) Viewed 24331 times
- 20170830_030839.jpg (160.91 KiB) Viewed 24331 times
- 20170830_044801.jpg (165.42 KiB) Viewed 24331 times
- 20170830_045346.jpg (189.81 KiB) Viewed 24331 times
- 20170831_003101.jpg (205.49 KiB) Viewed 24331 times
