LEDs on Spree
kevinv710
LEDs on Spree
Post by kevinv710 »
I received this free lovely baby from offerUp, so i use it as a tester for any Spree's stuff. I have a chance to converted some cheap chinese's LEDs lights into this...................any questions, suggestions that could share and learn together, would be appreciates!!!
key ON, engine OFF
with camera straight in angle
brake ON
turn signal ON
engine, headlight ON
Videonut
Re: LEDs on Spree
Post by Videonut »
super cool
eclark5483
Re: LEDs on Spree
Post by eclark5483 »
Now do like I did on my daughter's TaoTao: https://www.youtube.com/watch?v=XglRuEtSgjo
Re: LEDs on Spree
You need to get a blue headlight bulb to match. While the assemblies a unit, the inner bulb is separate... you can remove it with a dremel and some careful cutting. Use putty epoxy (ala JB Weld) to install new.
ped
Re: LEDs on Spree
Post by ped »
I like the leg Shield Kevin, that's different. Cool looking spree. :thumbwink:
eclark5483
Re: LEDs on Spree
ped wrote:I like the leg Shield Kevin, that's different. Cool looking spree. :thumbwink:
Oh yeah, now that you mentioned it, that is pretty cool. Wasn't even looking at it, was checking out the lights.
kevinv710
Re: LEDs on Spree
Post by kevinv710 »
Thank you, Gentlemen for good feedback...floorboard and leg-shield, taillight and blinkers was broken and missing pieces when i got it, so i just threw in and made something happen that legal enough ride-able for it.
When i posting this up, my all intentions was to learn and share to someone who interest add-on LEDs on Spree.....The basic setup to LEDs functioning properly not only complicated alone, but costly, times, skills and knowledge. I was lucky enough to find parts and with my limit knowledge, i was able to keep it under $30 budget, still got the job done.....Instead of writing down steps by steps how to, that might have confused you, due to my bad writing English skill, i decided to post up more pictures, some of them might hint you how's it works. Share with me, if you know how to set it up better, parts, anything...Again, thank you for checking out!
