**SOLVED** Polini Corsa Kit and Malossi Crank...?
MaxKulik
Post by MaxKulik »
Hi Everyone.
So I ordered the 72cc Polini Corsa Kit and the Malossi Full Circle Race Crank for my AF16E. I have just installed the crank was about to start assembling the head when I found out that the wrist pin bearing and the top of the rod do not match to the Polini kit. Has anyone else ran this combo and found out how to make the two work or did I just f*** myself lol. Thanks for the help in advance.
Exact Parts I bought:
https://www.scooterswapshop.com/product ... e-kit-72cc
https://www.scooterswapshop.com/product ... rank-af16e
bonesv
Re: **HELP!** Polini Corsa Kit and Malossi Crank...?
Post by bonesv »
MaxKulik wrote:Hi Everyone.
What is the part number on the malossi box?
Jonadz
Post by Jonadz »
I'm following this post as I'm about to do the same combo.
MaxKulik
Post by MaxKulik »
I found out that the bbk that was sent to me was the incorrect one. Problem solved.
jakubman1
Post by jakubman1 »
Who sent you the wrong BBK?
Meatball
Post by Meatball »
What was the part# of the Corsa they sent you?
MaxKulik
Post by MaxKulik »
I bought my BBK from Scooter Swap Shop. I already talked to Brandon and he has it covered. I still buy 99% of my parts from him and will continue to do so.
The part number that I should have gotten was 119.0077/R-1 but the part that I got was 166.0074/R. It was for a Yamaha something. Had I looked at the cylinder I would have noticed it was wrong right away but I didn't.
bonesv
Post by bonesv »
MaxKulik wrote:I found out that the bbk that was sent to me was the incorrect one. Problem solved.
Luckily you didn't install the wrong parts anyways. :oops:
I always try to have all my parts before a build so there's no delays or having to re-schedule my shop time.....that's a bummer man.
It probably has happened to a lot of us. :eyeroll:
Glad you got taken care of right away. Scooter swap shop has always been great! Mistakes happen and it's how it's dealt with that makes the difference!
MaxKulik
Post by MaxKulik »
Yeah, that's what I did. I over time just bought all the parts that I was going to need while I was getting things like the case cleaned up. I was going to put it all together yesterday but as soon as I started working with the bbk noting fit lol.
