Double Trouble....Elwood!
Meatball
Post by Meatball »
This is a Winter build project that's been ongoing in the Meatball garage. 49cc's is fun but it would be double the fun with 98cc's! A 50x50 stroker beginning with a bare bones AF16 block. First order of business is to clean the motor completely.
image3 (5).PNG (252.84 KiB) Viewed 16581 times
Meatball
Re: Double Trouble
Post by Meatball »
Remove/replace all trans bearings and oil seals. I had to cobble together some makeshift bearing pullers since a few of them cant be pulled with a typical puller.
image2 (6).PNG (242.35 KiB) Viewed 16580 times
image4 (4).PNG (254.01 KiB) Viewed 16580 times
Meatball
Re: Double Trouble
Post by Meatball »
The case was cut to fit the 50mm stroke crank. It also had the intake windows, boost port and a couple other key spots opened up. Crank fits nicely.
Meatball
Re: Double Trouble
Post by Meatball »
First pic is of the untouched boost port with a Corsa base gasket. Next pic shows it with the stroker bore's base gasket with port work.
image1 (6).PNG (252.67 KiB) Viewed 16580 times
Meatball
Re: Double Trouble
Post by Meatball »
This will have a ZX trans so more cutting is needed. Grind out a couple bumps around the clutch area and belt travel zone. It might be too much but its better than not enough and shred belts.
image4 (1).PNG (226.56 KiB) Viewed 16579 times
image1 (2).PNG (241.47 KiB) Viewed 16579 times
Meatball
Re: Double Trouble
Post by Meatball »
This will have either a Polini or Malossi for Ruckus variator so more grinding needs to happen. The Dremel gets another workout.
image2 (2).PNG (251.69 KiB) Viewed 16578 times
Meatball
Re: Double Trouble
Post by Meatball »
Now that grind work is done, case was cleaned of all shavings and prepped for assembly. Starting with trans bearing install. Freezing them overnight and heating up the case with a torch makes install a snap. They dont exactly fall in but just a few light taps to get them seated. Finding an OEM Honda 6202 bearing isnt easy. All others are readily available everywhere but that one. I gave up and went with a quality Taiwan replacement.
image1 (4).PNG (254.71 KiB) Viewed 16578 times
Meatball
Re: Double Trouble
Post by Meatball »
Crank bearings went in easy with the freeze/heat/tap method. Also squeezed in new motor mount bushings for good measure.
image4 (3).PNG (251.74 KiB) Viewed 16578 times
Meatball
Re: Double Trouble
Post by Meatball »
Test fitting the oil pump plug and sealing it from the inside with JB Weld. I did this before crank bearings went in. You can see a bit of the intake window opened up. I shouldve taken more pics but I was "in the zone" and forgot to stop and snap a few. This post is out of sequence. :sad:
image1 (3).PNG (252.2 KiB) Viewed 16578 times
Meatball
Re: Double Trouble
Post by Meatball »
Pulling the crank is too easy with the TUSK tool. Almost like cheating. To seal up the case I used Yamabond. You'd be surprised how many Honda shops use this stuff over Hondabond.
image2 (3).PNG (252.66 KiB) Viewed 16578 times
image3 (3).PNG (248.76 KiB) Viewed 16578 times
Meatball
Re: Double Trouble
Post by Meatball »
Now that the PG full-circle 50mm stroke crank is installed and the case is sealed up, I move onto the 50mm bore. I went with a PG for that as well. They make good quality products but some prep work should be done before install. Time to bust out the Dremel again!
Meatball
Re: Double Trouble
Post by Meatball »
Taking a tiny jeweler's file I carefully chamferred the ports to remove the sharp edges. Its not much but enough to knock down the razor-like edges to let the rings happily slide by.
image2 (1).PNG (229.84 KiB) Viewed 16578 times
Meatball
Re: Double Trouble
Post by Meatball »
The exhaust port had rather large casting flaws so it needed to be sanded down smooth. Then I polished it to a mirror finish to allow better flow of exhaust gasses and to reduce carbon build-up.
image1 (1).PNG (243.17 KiB) Viewed 16578 times
Meatball
Re: Double Trouble
Post by Meatball »
Chamferring the edges around the transfer area also help. Pic shows mid-process. The final outcome looked much cleaner.
image3 (1).PNG (238.17 KiB) Viewed 16578 times
Meatball
Re: Double Trouble
Post by Meatball »
After all the grinding on the bore, it was fully cleaned of all shavings and oiled. Now I can check the ring end gap. Surprisingly, one ring was within spec but the other was too tight and needed a couple passes on a file.
image3 (2).PNG (252.65 KiB) Viewed 16578 times
image4 (2).PNG (219.58 KiB) Viewed 16578 times
