Double Trouble....Elwood!
Meatball
Re: Double Trouble
Post by Meatball »
This build will have a Naraku Intake and a test fit is in order before continuing. Turns out, the Intake and Bore are simply too fat for each other fit happily. When pushed tight together the intake mounting bolts wont thread in. They needed a bit of grinding...Dremel, Where you at???
image1 (5).PNG (242.75 KiB) Viewed 12279 times
image2 (4).PNG (235.67 KiB) Viewed 12279 times
image2 (5).PNG (233.06 KiB) Viewed 12279 times
Meatball
Re: Double Trouble
Post by Meatball »
Intake and bore were installed after Dremel work with liberal amounts of Yamabond. Upgraded head studs were used over the weak stock bolts.
During jug install, base gasket thickness was determined and squish was checked after torquing down the matching 50mm head. After the motor is running, I may have to change head gasket thickness to obtain the ideal compression range. I realize this would change the squish but too high/low compression would be of higher importance. If squish is way off, I may need to mill the head or add gaskets to get it sorted.
Rear brake assembly, starter motor and Stator/flywheel installed. Crank oil seals greased and squeezed in to the proper depth. The 8.4:1 gears Ive chosen for this build will be pressed and installed in the next few days. Once the trans is sealed and filled I will move onto the vari/belt/clutch.
Re: Double Trouble
Greetings;
Nice work, and well-documented. Keep it coming!
sum_azn_kid
Re: Double Trouble
Post by sum_azn_kid »
Looks clean. Nice dremel work :thumbwink:
Super Dio ZX "Ube"
72 corsa
Meatball
Re: Double Trouble
Post by Meatball »
Gears pressed...installed...filled with precisely 3oz of special juice.
image1 (1).JPG (115.53 KiB) Viewed 12258 times
Meatball
Re: Double Trouble
Post by Meatball »
Installation of Vari/belt/clutch...Parts used:
Polini for Ruckus Variator
PG Aluminum Drive Face
Malossi ZX Belt
ZX Trans with Naraku Torque Driver
Stage6 Torque Control MK2 Clutch
Malossi Yellow Spring
Malossi Twist Control (the Motoforce ball bearing one in the pic didnt fit the Naraku Torque Driver)
Stage6 Vented Clutch Bell painted black because it looks cool. :lol:
image2 (1).JPG (142.75 KiB) Viewed 12256 times
image1 (3).JPG (129.56 KiB) Viewed 12256 times
Meatball
Re: Double Trouble
Post by Meatball »
Bench testing compression. I have a few head gaskets of different thicknesses. I initially had installed the thinnest one of 0.38mm. Check pic for results..
image1 (7).PNG (253.44 KiB) Viewed 12256 times
Meatball
Re: Double Trouble
Post by Meatball »
Compression of nearly 140psi is unacceptable...need a thicker head gasket...I switched to the next thickest I had which is 0.5mm...results below
Meatball
Re: Double Trouble
Post by Meatball »
The head gasket of 0.5mm dropped compression from almost 140psi down to 130psi....getting better but still not there. Putting in the fattest one I have which is a full 1mm thick.
image2 (2).JPG (66.47 KiB) Viewed 12256 times
Meatball
Re: Double Trouble
Post by Meatball »
BOOOOOOM....MONEY! 120psi on the button! :2thumbs:....almost ready to fly this bird!
image1 (2).JPG (87.79 KiB) Viewed 12256 times
benji
Re: Double Trouble
Post by benji »
Looking good!
ped
Re: Double Trouble
Post by ped »
Nice build meatball. Good work. :thumbwink:
Re: Double Trouble
...very well done. :urban:
Re: Double Trouble
You can run compression at 140PSI, but pretty much only with Avgas or 110 Octane racing fuel... at least I did. See F7
jakubman1
Re: Double Trouble
Post by jakubman1 »
Impressive balls !
Makes me wanna build a faster scooter..... :coolcruise:
