44MM Stroke Dio/AF16/AF18
pitobread
Post by pitobread »
Whats out there?
I've found Jiangwayne, which I don't really like.
and Taida which isn't quite 44 (43.6)
Am I missing any others?
Meatball
Re: 44MM Stroke Dio/AF16/AF18
Post by Meatball »
Athena?
pitobread
Post by pitobread »
Do you have a listing for it? I haven't came across it in their catalog, only OEM replacement.
Meatball
Post by Meatball »
Stock stroke is 41.4....youre looking for mini-stroker?
pitobread
Post by pitobread »
Yes. 44mm stroke.
sum_azn_kid
Post by sum_azn_kid »
https://dynoscooter.com/collections/hon ... -elite-dio
In case u didn't see on the other forum. :coolcruise:
Super Dio ZX "Ube"
72 corsa
NZHonda
Post by NZHonda »
sum_azn_kid wrote:https://dynoscooter.com/collections/hon ... -elite-dio
There is another forum?
Honda DJ1R project
pitobread
Post by pitobread »
49ccscoot.proboards.com
pitobread
Post by pitobread »
Well I ordered 2 of those 44mm Stroke Dio AF18 CMR from DynoScoot. Never heard of him but he sells a lot on ebay. Ordering the cylinder very soon too. Let the games begin.
Stock rod stroke ratio is 1.93
Most ministroke cranks have a rod stroke ratio of 1.82
Modern high strung streetbikes are 2.0+
My build will be 2.07 with a 91mm connecting rod. Ordered today from a local shop as they had them cheaper than I could find anywhere. ProX 03.1102 Note that the big end is 1.5mm bigger, and will need to be resized (width), or the crank modified. I think the latter so I can use the wider bearing. You could also use a ProX 03.2104 which is 2mm wider on the big end and 1mm shorter @ 90mm and give a rod stroke ratio of 2.05.
Zoom.
sum_azn_kid
I've bought from them before. They are good sellers.
Super Dio ZX "Ube"
72 corsa
pitobread
Post by pitobread »
TWH Still makes one as well, sans oil pump drive.
44mm, looks allright
sum_azn_kid
So how did the CMR cranks turn out?
Super Dio ZX "Ube"
72 corsa
pitobread
Post by pitobread »
Should be here soon. Few more days.
pitobread
Post by pitobread »
Got them today, The cranks are very nice quality, good machining, nice grinding on the bearing journals, nice threads and splines.
The rod is kinda wimpy. It looks like a 2AB rod without the words on it. Im tossing these rods anyway so no matter to me. A fella could throw a Pro-X rod on there and have a stout crank.
