Crankcase re-assembly
sum_azn_kid
Post by sum_azn_kid »
I've always used a crank puller to assemble dirt bike and scooter cases (as the Honda service manual shows). But I noticed a lot of Europeans on YouTube and forums use the heatig method(heat up crank case to expand the metal). Which method better? And your thoughts?
Super Dio ZX "Ube"
72 corsa
Chubbyfunkmonkey
Re: Crankcase dis-assembly
Post by Chubbyfunkmonkey »
I use a hammer, not recommended
1989 sb50p
2005 ruckus 50cc custom
2009 ruckus 125cc 4speed
pitobread
Post by pitobread »
Once you use heat, you'll never go back. It slips together, no banging or fuss. I put my cases on my space heater in the garage, they get uncomfortably hot, then it literally slides together.
sum_azn_kid
Re: Crankcase re-assembly
Do you freeze the crank and bearigs too?
Super Dio ZX "Ube"
72 corsa
If the cases are oil-free, and Ms. Sum_Azn isn't on the premises, heating to 300 or so AND freezing the crank makes things so much easier. I've done the same thing to install the case bearings, and had one literally drop into place without a single blow. The frost on the bearing acts as a lubricant and the clearance improves enough for force not to be necessary. Welding gloves make it all possible.
kuromi
Post by kuromi »
@Wheelman - I've always wondered if the frost on frozen bearings has any ill affects later on.
Have you ever had any issues e.g. with disassembly?
1983 Melody Deluxe II / ND50MC
1984 Melody Mini / NP50D
1979 Simson Schwalbe KR51/1 (think 2 wheel trabant/ East German Honda Cub)
sum_azn_kid
Wheelman-111 wrote:Greetings:
Sum_azn_girl doesn't use the oven so it's fair game... wish she did though :eyeroll: haha.
Super Dio ZX "Ube"
72 corsa
Never had an issue. That water boils away pretty quick with a 300-degree case, plus it's bathed in oil...
kuromi
Post by kuromi »
Cheers, Wheelman :thumbwink:
