This is an old thread and Im sure the OP is long gone but I was only responding to the misinformation posted by kingdele. His claim was that removing the backing plate on a restricted SE50P variator and using the flat ÔÇ£restrictedÔÇØ ramp plate would net gains....it would not.
Technically, you could use the pulley half of any SA50 variator but the stock 10mm boss would need to be used. However, you would still need to source a ramp plate with a 10mm diameter hole to accommodate the crankshaft.
The ramp plate can be used from an 85ÔÇÖ NB50 Aero, an un-restricted SE50(non-P) or Polini also makes a complete variotor for Af05. The Aero ramp plates were stamped ÔÇ£US2ÔÇØ sold in the USA. Ive seen overseas ramp plates stamped ÔÇ£UK2ÔÇØ (United Kingdom) and ÔÇ£FR2ÔÇØ (France) that are identical to our US version, although, the names of these foregin scooter models escape me.
Variator De-Restrict Possibility for SE50P?
Re: Variator De-Restrict Possibility for SE50P?
In my previous post, I have pointed out that you could use the ramp plate from the early sa50 elite '88-'93 af05 motor which has the 10mm crankshaft. I mentioned that the use of the stock af05 boss would have to be used with the new pulley. I was pointing this out for anyone "searching" for correct information and I also stated that if I was incorrect, someone please point it out.Meatball wrote:This is an old thread and Im sure the OP is long gone but I was only responding to the misinformation posted by kingdele. His claim was that removing the backing plate on a restricted SE50P variator and using the flat ÔÇ£restrictedÔÇØ ramp plate would net gains....it would not.
