M1ZZHEAD wrote:The guy that bored it out said my air/fuel was off but the mechanic at work thinks there was something in it.
What did the guy ÔÇ£bore outÔÇØ?
The mechanic was wrong, there was nothing in there but excessive heat. Thats what caused the piston to smear molten aluminum on the cylinder wall. Always on the exhaust port too...tell tale sign.
I live about 30mi North of Seattle and you live close enough that I can provide somewhat close jetting recommendations. Our relative humidity and elevation will be very similar but just know that youÔÇÖll need to dial it in to accommodate your riding style and if mostly city or highway. Mine spends 90% of its run time at full throttle so I have it dialed for that with the trade-off being a rich idle and its a dog under 7k rpm. That being said, heres how one of my scoots are set with:
Corsa
Arrow
24mm Polini with 40/114 mixture screw is ONE turn out.
Even set-up like this IÔÇÖve reached scary temps of 400 when running it for hours, climbing hills and hammering the throttle to death. I beat the living * out of my scoots because thats my fun. You could try an even higher jetting and twist the screw out more...watch temps.
Good info: when jetting, a CHT is a must. YouÔÇÖll burn up bore after bore without it. If you DO have a temp gauge and youre trying a new jetting, when you blast a long WOT run and temps are at like 320 and jumping up 20deg at a time...stop!. Because temps rising TOO fast at that range. They can jump in the 200ÔÇÖs...but not 300ÔÇÖs.
If youre looking for a new Corsa, PM me. I cant point you in the right direction.
