Honda elite Af05 engine swap
kokasdim
Post by kokasdim »
Hello,
I got a honda elite af05e engine non variated.
Is it possible to swap with another engine?(af16/18 etc.)
What do i need?
And what engine to choose?
Thank you :)
eclark5483
Re: Honda elite Af05 engine swap
Post by eclark5483 »
You'll need to fabricate the mount from an af16 and weld on a tab for the shock to mount. Little bit of wiring too.
The answer is YES, swaps can be done.
Examples are discussed here regularly.
For starters, you will need to decide which engine you are going to use.
AF16 being the preferred choice.
Modifications must be made to the engine mount.
Members here have offered modified mounts for sale.
This is where you should start using the Search...click on Quick links at the top, left of this page.
Meatball
Post by Meatball »
Swap that shizz!
