Just another AF16 Spree Swap
Meatball
Re: Just another AF16 Spree Swap
Post by Meatball »
Theory: the petcock functioned fine for many years with the vac of the Spree motor...once you apply it to AF16 pressures, it gave up the ghost?
I know the vac pressure differences are small, if any, but some components develop a functioning memory if used in repetition for long periods of time. Change one tiny thing and they go kaput. Unfortunately, finding a replacement petcock with the correct threads for the Spree fuel tank is challenging. MOST of the ones sold on Ebay that claim to fit Spree/NQ50 have incorrect threads. Ive bought 3 from different sellers and 0 would fit. Others have reported success so its a crapshoot there. If you try to force the wrong threads on and jack up your fuel tank threads, your goose is cooked and you buy a new tank.
Options:
1. Find a good used OEM petcock either here or Ebay
2. Install an in-line manual fuel valve
3. Sell a kidney and pay the sky high price of a NEW OEM petcock from Ebay if one ever pops up
eclark5483
Post by eclark5483 »
What year Spree is that again? I think I have one out in the garage.
eclark5483
Just checked.. yeppers, I have one, brand new. Should (allegedly) work for an 86-87'. I'll try to remember to test it out on the tank of the spare 86' in my garage tomorrow or this weekend when I get time to confirm it works. Would have to tear plastics off and it's too late in the evening to be fiddling around, need to get to bed.
Meatball
Post by Meatball »
Id jump on that if it fits, ntonar ^^^
Ive gotten stuff from eclark before...always good price, ship and quality.
ntonar
Post by ntonar »
So I got some time to work on the spree, what I thought was a bad petcock ended up just leftover the gas in the line draining. Next I checked the float to insure it was making a seal when the bowl was full. After thinking for a but I forgot I never adjusted the air/fuel screw and it was just threaded in about a 1/2 turn. I set it to 1-7/8 turns out and the fuel leak stopped. I gave her about three kicks and bam! She fired right up :coolcruise:
Video :thumbsup:
https://youtu.be/yAB42Jn9G2g
eclark5483
Good deal. Glad to hear that.
ntonar
Post by ntonar »
eclark5483 wrote: Thu Aug 16, 2018 9:18 pm Good deal. Glad to hear that.
But thank you for the offer!
I have new rear brake shoes coming. I ended up ordering the EBC 333 for the rear. Currently I have no rear brakes and the adjustment nut is maxed out on the (SA50) cable. I didn't check the shoes before I installed the rear wheel but it would probably be best to refresh them anyway. After the braking issue if solved the only thing left is the intake for the carb. I am going to try doing what meatball said and tuck something behind the stock panel and restrict it to mimic a stock airbox.
Here is the crew (one of the red spree's got the motor swap)
ntonar
Post by ntonar »
Wow the rear brake shoe pad is pretty much non excising!
Meatball
Post by Meatball »
:shock: Can imagine what the wheel drum looks like
Nice collection you have there. Cherry looking 88’ gets my vote. Need a 16 swap w/Corsa on that baby next! Can use the 88’ motor in one of the Spree’s. 8)
eclark5483
Your garage reminds me of mine. Scooters everywhere (and 1 motorcycle). You got me beat by a couple scooters though. Soon as I find the right ones (and my wife doesn't kill me), I'll catch up to ya. My wish list is for a Gyro or 2 and maybe another Indian. Either another AMI-50, or maybe a new Indian... uh wait, can't talk about that. Signed a Non-disclosure agreement. :thumbsup:
ntonar
Post by ntonar »
So I got the new rear brakes installed and functioning along with a new air filter. She runs and great with only one problem. This engine was restricted, but it hit 28 mph really fast! Exhaust has the washer drilled and I removed the plate from the Variator. Next I plan on ordering a jet kit from the scooter swap https://scooterswapshop.com/products/je ... 6775616773 and maybe removing the oil pump and run premix. I do have an extra SR pump but it has a slow leak, I am not sure how I feel about using a restricted pump tied open.
The scooter is going to sit till I get it rejetted
ntonar
Post by ntonar »
Some small updates
New Belt installed
Installed an oil delete plug along with a #84 jet. It was raining last night so I couldn't take her for a ride but looking forward to it tonight
ntonar
Post by ntonar »
Took her for a ride tonight and she runs perfect! Only two things left, balance the front tire and find an option for an air filter that will fit under the stock panel.
eclark5483
They sell filters that angle out. If anything, you can get one, fashion the original coupler to extend it further, and that should tuck in nicely. Consider swapping the intake for an aftermarket dio as well. Fits just right on mine. Barely clears the shock, but it works.
Meatball
Post by Meatball »
This is the ONE... UNI filter part # UP4112-AST
Remove the red foam outer sleeve and it fits like a glove under Spree plastics.
IMPORTANT: you MUST MUST MUST restrict this filter! Cant run it free-flowing. I used the bottom end of a basic plastic water bottle. Cut the bottle in half and it slides over the filter perfectly. Tape it on with tight wraps of electrical tape at the base. Poke holes in the bottom for air flow..I used a soldering iron for melting perfect holes.
HOW MANY holes, you ask? You’ll need to play with it and find out what your motor likes. I jacked with mine for 2wks and finally got it perfect.
