Locale/Elevation: Toronto, ON / 76m above sea level
Average operating temp: 25-30° C / 77-86° F
Engine
AF18E
Cylinder/Piston: Naraku Aluminium 48mm 75cc
Cylinder Head: Naraku 48mm
Spark Plug: BP8HS
Crank: Not stock – not sure what make though, previous owner install
PSI: Not sure of the exact psi however it feels really high, better than my Contessa ever was. Likely 130+
Exhaust
Giannelli Limited Series 70cc (similar to the Arrow)
Intake
Air filter: mini cart air box
Intake manifold: OKO 26mm reed block intake
Reeds: vforce 8 petal reed block
Carburetor: 21mm OKO PWK blk
Pilot Jet: 40
Needle / clip position: 3G9 (stock) #2/5 clip position (#1 being leanest)
Main Jet: 88
Air Screw: 1 turn out
Idle screw: .25 turn out, Idles at 1500-1750 RPM
CVT
Variator: Kitaco High Speed Pulley
Weights: 5g rollers - 30g total
Shims: 0
Drive Boss: SYM DD50
Belt: BANDO 669-18-30
Torque Driver: DIO ZX Driver – Over range 118mm vs stock 108mm
Clutch: KOSO Performance Clutch
Clutch Springs: 2000rpm red
Contra Spring: 1000rpm blue /w Motorforce twist control bearing spring seat
Clutch Bell: TWH light weight
Other additions
Kitaco 120km/h speedometer
Runleader RL-HM035LT Tach/Hour/Cylinder head temp sensor
Full SUPER DIO body kit - Pearl white paint
Front Disc brake conversion
The carb / CVT tune now feels great overall, Quick on launch with the mid range at about 8k rpm and WOT getting just under 10k. Haven't ran WOT for more than a minute or so since the cylinder is still new, After taking it easy for 100km or so I'll have to see what the top speed I could get would be.
