1988 Elite SA50 carburetor
I am a recent owner of a 1988 Honda Elite SA 50. We love this scooter but I quickly realized this thing needs help in the carburetor department. I got the mixtures working well enough to idle right and make it rideable but discovered the carb had a small gas drip and horrible gas mileage. I tried a new bystarter but made it worse where it won’t stay running. I’m not super mechanical so figured I would have local dealer rebuild carb. They said find the parts and we will rebuild. From the dealers response finding a rebuild kit to keep oem carb is difficult. I don’t want an aftermarket Chinese carb so what is my next step? Thoughts?
Re: 1988 Elite SA50 carburetor
First: stay away from the dealer. They charge way too much for things that are way too easy...even for those not mechanically inclined.
Second: read the wiki walk-through and educate yourself on the inner components of the stock carb. They are truly as simple as pie and consist of maybe 10 pieces.
Third: diagnose the leak! An easy way I use is to clean and dry the outside of the carb completely...spotless as you can. Wrap the carb in a paper towel (and tape) and run it. Inspect paper towel for wet spots to locate origin of the leak. Now you know the problem.
Fourth: fix it by buying the gasket, float needle, o-ring or whatever...and install it. Give the carb a good clean while youre there and be happy you just saved lots of money.
Thanks Meatball for the advice. Do you know a good place to buy the gaskets, float needle, o-ring etc.? I will try to remove the carb myself and determine all the inner components.
Determine what you need, then I will try to provide a source. There isnt ONE place to get everything usually.
How about an online honda parts store?
http://shop.jerseyshorepowersports.com/ ... sp?srt=mfg They should have gasket kit which has all the o-rings included.
Sounds good Meatball.
I will take a look at that site Bonesv. Thanks
I also will need to eventually replace a few carb gaskets on my SB50p. Right now it appears the float bowl gasket is seeping a little bit. Don’t want to pull carb unless I have everything, especially the manifold/reed gasket. Not sure why stuff like this gets discontinued when there are a bunch of these scoots still in service.
I refuse to tip-toe through life, only to arrive safely at death.
I’ve had to make gaskets, it’s not too difficult with a good knife and smooth surface to cut on.
? The OEM bowl gasket isn’t rubber?????
I think my SB50p carb might be different, not sure..
Sorry, I mean't the intake base gaskets. I was not aware the bowl gasket was no longer available. Edit: The title of your post is for sa50 parts. Now you ask for sb50 bowl gaskets? I am confused but you are correct about the sb50 - it is different. I don't recall having a leaking bowl gasket on any of the 20 or so elite 50cc carburetors I have seen. The leak usually comes from the o-ring missing, or damaged in the f/a adjustment screw and dripping down onto the bottom of the bowl. Double check it by cleaning off the side and bowl, then run it for a few miles. Inspect immediately after with paper towel.Shnapper wrote: Sun Sep 16, 2018 2:57 pm ? The OEM bowl gasket isn’t rubber?????
sb50 was only made available to usa for 3 yrs.Shnapper wrote: Sun Sep 16, 2018 2:07 pm I also will need to eventually replace a few carb gaskets on my SB50p. Right now it appears the float bowl gasket is seeping a little bit. Don’t want to pull carb unless I have everything, especially the manifold/reed gasket. Not sure why stuff like this gets discontinued when there are a bunch of these scoots still in service.
bonesv wrote: Sun Sep 16, 2018 6:58 pmSorry, I mean't the intake base gaskets. I was not aware the bowl gasket was no longer available. Edit: The title of your post is for sa50 parts. Now you ask for sb50 bowl gaskets? I am confused but you are correct about the sb50 - it is different. I don't recall having a leaking bowl gasket on any of the 20 or so elite 50cc carburetors I have seen. The leak usually comes from the o-ring missing, or damaged in the f/a adjustment screw and dripping down onto the bottom of the bowl. Double check it by cleaning off the side and bowl, then run it for a few miles. Inspect immediately after with paper towel.Shnapper wrote: Sun Sep 16, 2018 2:57 pm ? The OEM bowl gasket isn’t rubber?????
Yeah my bad on the carb model/scooter version, I hitched on to this thread thinking they were the same carb.
Wiped it all up(wasn’t much)and rode it a little bit. I don’t see anything that concerns me. Before I rode it, I pulled air box as I suspected it was coming from the box boot. I found a puddle of oil in the air box boot and wiped it out. My initial inclination was the air box as the residue was higher that the A/F screw so I’ll keep my eye on it. I most likely messed up in two ways..
1. sometimes I pop(stationary wheelie)up the front end to turn it around in my garage.
2. I just hand cut some UNI air filter foam and over oiled it which didn’t help either.
I recently kitted my 2001 Elite carb ordering from 2WheelPros.com. Evidently the stuff for 1988 is more scarce, but you can see what they have here.
Now that the Florida heat is gone i removed and took apart my Elite SA50 carb. Trying to figure out what is wrong. Should I just use carburetor cleaner spray? The carburetor doesn’t look too dirty. The plastic float seems bouncy (I have a new one anyway). I was hoping to see something obvious. I did notice the metal housing you screw the jet into has a chip. Will try to photograph that. Thoughts?Meatball wrote: Sat Sep 08, 2018 7:38 pm Determine what you need, then I will try to provide a source. There isnt ONE place to get everything usually.
