Just another AF16 Spree Swap
Re: Just another AF16 Spree Swap
Some part are here, top end should be here this week.
- Part1.jpg (411.12 KiB) Viewed 26573 times
So fresh and so clean
- Engine1.jpg (328.27 KiB) Viewed 26459 times
A most sanitary and well-executed build, well-done.
Word of Caution: The black cup on that air filter quiets the intake moan but is extremely restrictive in my experience. Well-tuned for an open foam filter, my Fabrizi would barely run when that cap went on. Probably needs 3 or more jet sizes Down, with commensurate decrease in power, if you install it.
Will the filter be unrestricted/plenty of air if I take the cover off?
Dry fitting parts.
Dry fitting parts.
- Fitting1.jpg (279.74 KiB) Viewed 26449 times
Sorry, I cant figure out this attachment thing
If it's like the filter I had, there should be a foam cylinder under the cap - like a UNI. In that case there's almost no restriction - AND no sound dampening. The roar from the left side can compete with the exhaust racket.
Rear wheel prox sensor mount for the vapor.
- Prox Mount2.jpg (251.77 KiB) Viewed 26413 times
- Prox Mount.jpg (293.42 KiB) Viewed 26413 times
- Prox Mount1.jpg (223.29 KiB) Viewed 26415 times
Clean and simple.
4 heat cycles in, might take it for a ride tomorrow. Next step in a met front stem, wheels and a disc setup.
- Spree1.jpg (312.93 KiB) Viewed 26400 times
- eclark5483
That thing is just unbelievably sweet looking. Do you plan on doing any VHT paint on the pipe?
I've heard mop n glo floor wax works great too
I am not planing on painting the pipe, it looks to be clear coated from the factory. If it starts looking rusty I might re-coat it.
It turns brown after a few rides. Gives it a nice cooked look.
It has been some time but I am still working on the spree. I did get to take it for a short ride up and down the street but am still in the breaking in process.
Without many projects this winter I decided to continue working on the spree. Next step is/was larger wheels with a nice tires and a front rotor brake. I ended up going with a metro stem and NCY wheels with 90/90 S1’s. The rest still needs to get on order but this is where I am at. Big thanks to the Scooter Swap Shop for great info and helping with tons of questions.
