Just another AF16 Spree Swap
ntonar
Re: Just another AF16 Spree Swap
Post by ntonar »
Some part are here, top end should be here this week.
ntonar
Post by ntonar »
So fresh and so clean
A most sanitary and well-executed build, well-done.
Word of Caution: The black cup on that air filter quiets the intake moan but is extremely restrictive in my experience. Well-tuned for an open foam filter, my Fabrizi would barely run when that cap went on. Probably needs 3 or more jet sizes Down, with commensurate decrease in power, if you install it.
ntonar
Post by ntonar »
Will the filter be unrestricted/plenty of air if I take the cover off?
Dry fitting parts.
The attachment Fitting1.jpg is no longer available
ntonar
Post by ntonar »
Sorry, I cant figure out this attachment thing
If it's like the filter I had, there should be a foam cylinder under the cap - like a UNI. In that case there's almost no restriction - AND no sound dampening. The roar from the left side can compete with the exhaust racket.
ntonar
Post by ntonar »
Rear wheel prox sensor mount for the vapor.
Prox Mount2.jpg (251.77 KiB) Viewed 26410 times
Prox Mount.jpg (293.42 KiB) Viewed 26410 times
Prox Mount1.jpg (223.29 KiB) Viewed 26412 times
bonesv
Post by bonesv »
Clean and simple.
ntonar
Post by ntonar »
4 heat cycles in, might take it for a ride tomorrow. Next step in a met front stem, wheels and a disc setup.
eclark5483
Post by eclark5483 »
That thing is just unbelievably sweet looking. Do you plan on doing any VHT paint on the pipe?
benji
Post by benji »
I've heard mop n glo floor wax works great too
ntonar
Post by ntonar »
I am not planing on painting the pipe, it looks to be clear coated from the factory. If it starts looking rusty I might re-coat it.
Meatball
Post by Meatball »
It turns brown after a few rides. Gives it a nice cooked look. :lol:
ntonar
Post by ntonar »
It has been some time but I am still working on the spree. I did get to take it for a short ride up and down the street but am still in the breaking in process.
Without many projects this winter I decided to continue working on the spree. Next step is/was larger wheels with a nice tires and a front rotor brake. I ended up going with a metro stem and NCY wheels with 90/90 S1’s. The rest still needs to get on order but this is where I am at. Big thanks to the Scooter Swap Shop for great info and helping with tons of questions.
ntonar
Post by ntonar »
