fuel valve problem 85 spree
Can't get fuel to the carb on 85 spree. Lines are clean. Removed the fuel valve. Problem appears to be diaphragm. Will I need to replace valve? Is it possible that there is inadequate vacuum pressure to engage diaphragm? Where can I get the valve, if needed? Thanks.
Fuel
I'm not sure that it can be rebuilt... I would check eBay or email Greg ( uspmale@yahoo.com ) for the part, you could always contact your local Honda deliership too (might be suprised what parts are still stocked).
Yes, low vacuum (or bad compression) could cause fuel delivery probelms... but I'd error on the valve vs. compression issues. You could always do a compression check.
2002 SR 50 DiTech
- Malossi 70cc BBK, ECU, clutch springs, red air filter - Giannelli exhaust - Boyesen 712 power reeds - 7.2g LeoVince
xela_p2004
- Farfignugin
xela_p2004
Of course not, there is to lines, the one directly under the fuel valve is the vacuum, thats the one you want to suck, also remember to remove the fuel line to see if gas comes out, just a little sucking will cause a lot of gas to pour out if the fuel valve is working properly, thats from experience.
