i recently bought a spree with a dd50 drivetrain swapped in.
i know! "don't buy stuff like this cause you don't know what the last guy did to it!"
too late. now i get the pleasure of learning a lot from my mistake
long story short, it wasn't running super hot when i got it (of course it ran great when i test rode it but as soon as i handed over the cash i started having troubles). after cleaning the carb, replacing the petcock, swapping out the airbox for a foam filter and * around with the idle and throttle cable, i've actually got it running fairly well - it gets me to work and back all right.
the good news is that it's fast as *. maybe even faster than i want it to be. but i know that performance gains mean worse mileage. if i can go 35-40 i'm more than happy. my main issue right now is the gas mileage. i'm probably getting 30ish mpg right now, which means with my commute, i have to fill up twice a day just to make sure i don't run out of gas in case i need to run an extra errand or something.
i'm not looking for a clear cut answer to my problem, but given that it has a stock pipe and what looks to be a stock carb (or a cheap replacement for a stock carb), where should i start looking for places to improve? the autochoke is disconnected and i don't know where to hook that back up (came that way). i know it's running rich which is why i swapped out the airbox - it would barely idle before i did that. do i just need to downjet it? would putting heavier rollers in the variator get me much of an improvement? if i can get even close to 60mpg that would be killer.
sorry if that's a mess of info and unclear questions. i'm pretty new to working on scoots in general but i really want to learn - i've always wanted a spree/small scoot and now that i have one, i want to know as much as i can about it. i work in IT so i'm used to learning things on my own but there's a lot of 'common sense' that is hard for me to fill in the gaps with since i don't know much to begin with.
thanks for reading
