Easy Peezy Stretch Mount.
ASpreeOfJoy
Post by ASpreeOfJoy »
Hello fellow rider's i was to share my mock up of my 12 inch stretch for me spree, i wanted something simple and heavy duty so i used....
1/2 by 3 feet of steel cut into 3 bars
1 original spree mount
30 minutes of free time.
Sanding disk grinder
Welder
Cut them even and aligned them.
scooty 7.jpg (89.17 KiB) Viewed 10019 times
Used a flapper wheel to mock up a u shaped valley.
A little mock up....
scooty 3.jpg (86.21 KiB) Viewed 10019 times
ASpreeOfJoy
Re: Easy Peezy Stretch Mount.
Mock up tacked up
Mock up tacked up
Not tightened up but how far i will be.
scooty 9.jpg (87.69 KiB) Viewed 10008 times
Bent my tact welds till it was straight.
scooty 4.jpg (83.78 KiB) Viewed 10008 times
bonesv
Post by bonesv »
Nice :mrgreen: That should be fine.......until you mount up a DIO!!! :nervous: :nervous: :nervous:
Really tho, this looks like a nice and simple stretch-stock-spree mount. Although not everyone has a welder or skills of that nature but one could be found. Thanks for the motivation!!! :thumbwink:
You may have to find a different rear fender :lol:
ASpreeOfJoy
bonesv wrote: Sat Jun 29, 2019 3:42 pm Nice :mrgreen: That should be fine.......until you mount up a DIO!!! :nervous: :nervous: :nervous:
The dio motor would likely pop my welds lol, i have 1 or 2 more bars to add for less flex( if any). Another 1/2 thich for the side with more room and 1/4 inch for the opposing side with the tiny stub on the motor side of the mount. I have a friend who is going to tig what i mock up when that time comes for the dio. Im realy hoping to use my panels, worst case i will heat a razor and trim the bottom to fit. I have to cut the license plate mounts to clear room for the tire. I have some more stuff planned!
ASpreeOfJoy
Made the mount a little safer by adding some metal as support. I will buy another piece for the left and right sides for more flex proofing. Got it straight enough.
arrow 2.jpg (158.87 KiB) Viewed 9937 times
RichardUrena
Post by RichardUrena »
Nice welding work. Let's just hope it holds up. I'm not a good welder so...props to you and your work!
