Sb50p sticker bomb build
benji
Re: Sb50p sticker bomb build
Post by benji »
I have a jet drill kit, which is nice for verifying jet sizes and also redrilling jets to bigger sizes.
Chubbyfunkmonkey
Post by Chubbyfunkmonkey »
I've been looking to get a good drill bit set specifically for jetting, but for now I've just been using an x-acto knife and solder. When everything is where I want I'll measure the hole and buy the jet.
1989 sb50p
2005 ruckus 50cc custom
2009 ruckus 125cc 4speed
benji
Post by benji »
Look for a 'jet drill kit' it's a kit with a bunch of drill bits jet-sized. I've got one a good buddy gave me, very handy.
Here's one, kinda small tho
https://m.ebay.com/itm/New-21pc-Mini-Dr ... mwBanner=1
Chubbyfunkmonkey
I've been on the look out for a nice kit but most of the ones I've seen seem kinda cheap.
1989 sb50p
benji
Post by benji »
I think alot of em are haha. But hey it is what it is. I barely use mine unless I'm tuning, then it's mostly used for checking jet sizes. Sometimes there a little off.
Here's a bigger one. The one I got had ONLY the #60 size and down - numbers inverse to the diameter. Measuring each shaft with a micro-caliper gives a fairly accurate hole size. I found clamping the drill bit and spinning the jet down onto the cutting end easier than tryin to spin the drill. The bits cut the soft brass of the jet like buttah. Shop around the HF website for several other smaller bit kits.
benji
Post by benji »
Here's what I got. Just used it to ream out a 76 MJ to a 90 MJ, In .05 increments (75,80,85,90) worked great. Got one of the bits stuck in my finger tryna put it back in the pack tho.
Chubbyfunkmonkey
Back! I was out of town for a while but I'm back in my garage finally. As for the drill bits, I caught my girlfriend snooping on the forum and I think I may be getting a new set this xmas
1989 sb50p
Chubbyfunkmonkey
I got home to find a dying battery. Not sure if the problem is with the battery or the charging system, but I'm headed out to get a new battery so I can find out.
1989 sb50p
Chubbyfunkmonkey wrote:I got home to find a dying battery. Not sure if the problem is with the battery or the charging system, but I'm headed out to get a new battery so I can find out.
Throwing a new battery at it will do nothing to diagnose your issue.
Instead, jump to a 12 volt source to start scooter if you must, then meter across the battery terminals to read outputs... :urban:
Chubbyfunkmonkey
The battery was bad. I put the new one in and gave the throttle a pull, the voltage jumped up.
1989 sb50p
Chubbyfunkmonkey
I'm guessing one of the cells was shorted because I was only getting 11-12 volts with the motor running before
1989 sb50p
Chubbyfunkmonkey
New Upgrade !
cheap and easy. all you need is a screwdriver and some stolen nail polish from your girlfriend/wife. or use your own, i won't judge
ImageIMG_1699 by chubbyfunkmonkey, on Flickr
I consider it a safety feature. now if the needle gets in to the red i know its time to wake up
1989 sb50p
BarryHog
Post by BarryHog »
WOW
What an awesome idea. Not only is the Zuma cylinder cast iron but it also already comes without an intake port so no need to add epoxy for the casereed Bulletproof and powerful setup
If you ever make more cases and sell them, please let me know...
