I have a v8, 72cc malossi cast iron, 28oko..
About last week I noticed my exhaust started to leak on to my block.
On my way home from work it leaked very bad, carb started to flood/ bog once I rev my bike.
I replaced spark plug and my exhaust gasket, cleaned carb.. did a test run and it still leaks(not as bad as my ride home), only bottom of exhaust leaks.
Any help would be appreciated..also not sure if this is the problem, one of my exhaust screws broke from block where you would screw in both bolts to hold down exhaust
Exhaust leak
Re: Exhaust leak
I would try one of these.
https://scooterswapshop.com/products/re ... 411f&_ss=r
Also here are some replacement studs
https://scooterswapshop.com/products/ex ... 9770&_ss=r
Re: Exhaust leak
DUH ! !...YES the broken exhaust bolt(stud) IS THE PROBLEM.Rajahdat wrote: Thu Jul 11, 2019 1:44 am I have a v8, 72cc malossi cast iron, 28oko..
smh...mm
Re: Exhaust leak
It’s not the stud where exhaust and bore meets, it’s the screws where fan is the broke on block..I’ll post a pic soon
Re: Exhaust leak
Yes probably the top one. I have drilled one out before and used a tap to thread it to use a new larger size bolt. If it's the block that broke off then you should replace the case half.Rajahdat wrote: Thu Jul 11, 2019 11:04 am It’s not the stud where exhaust and bore meets, it’s the screws where fan is the broke on block..I’ll post a pic soon
Re: Exhaust leak
Sorry idk how to add pics on forums..
https://imgur.com/Pi4imxD
I still have piece that broke of could I jb weld it?
Re: Exhaust leak
no JB Weld you need new case half. Is it af16 or af18? I have af18 if you need it.
