FYI Stock PA Carb Pilots Exist
nateberrier
Post by nateberrier »
Taz has spoken to a leprechaun apparently. He has Spree/Elite/Aero pilot jets for sale.
https://www.ebay.com/itm/Honda-Spree-NQ ... SwWxNYw5zb
1986 Aero White -- Stock With Keli Var
1985 Aero Red -- Af05 Malossi BBK + Keli Var
1985 Aero Red -- Af16 Corsa / Fabrizi Pipe / Polini 24 PWK / Athena Stuffer Crank
eclark5483
Re: FYI Stock PA Carb Pilots Exist
Post by eclark5483 »
He's had them for quite a while, I've tried them on the dyno, the #34 pilot is overall still the best one to use if you are thinking of changing yours or replacing it.
nateberrier
eclark5483 wrote: Tue Jul 30, 2019 6:47 pm He's had them for quite a while, I've tried them on the dyno, the #34 pilot is overall still the best one to use if you are thinking of changing yours or replacing it.
Im trying to do a BBK with the stock carb. Im gonna try the 40 with the malossi kit on AF05
eclark5483
Malossi kit? I believe that is only for the variated version of the AF05. If that's what you are working with, then a bigger pilot will work out, on a Spree engine, absolutely not.
nateberrier
eclark5483 wrote: Wed Jul 31, 2019 3:04 pm Malossi kit? I believe that is only for the variated version of the AF05. If that's what you are working with, then a bigger pilot will work out, on a Spree engine, absolutely not.
Yes its a variated AF05 on an Aero
