Project "Ube" Super Dio
sum_azn_kid
Re: Project "Ube" Super Dio
Post by sum_azn_kid »
Super Dio ZX "Ube"
72 corsa
808allday... :rock:
ntonar
Post by ntonar »
very nice!
sum_azn_kid
Thanks guys. I got the wheels on, still looking for polished hubs to match. Also put the ZX yellow headlight back on, for now...
Super Dio ZX "Ube"
72 corsa
sum_azn_kid
Super Dio ZX "Ube"
72 corsa
ReB0RnSativa_00_
Post by ReB0RnSativa_00_ »
So fresh and so clean clean!!! :coolcruise:
sum_azn_kid
ReB0RnSativa_00_ wrote: Sun Sep 15, 2019 8:19 pm So fresh and so clean clean!!! :coolcruise:
Thank you. Hopefully I can get the wheels back on in time for your visit. I need new bearings for the polished hubs I got :2thumbs:
Super Dio ZX "Ube"
72 corsa
sum_azn_kid
I finally put in the new MHR full circle crank and new corsa on my spare block. Noticed the driveface splines on the crank had some play with the driveface. Didnt think anything of it until I started up the bike. Burning belt smell and it whined like a super charger. $300 crank defective from factory I guess. Nvr buying malossi again.
Ended up removing the boat anchor and buying a PG stock stroke stuffed crank. Installed into the case after making sure the drive face splines matched up good. Topspeed didnt seem all that much better from my old corsa and stock crank.
I was wondering why my bike was toping out at only 60mph when it could do 65mph before the motor swap. When I went into the cvt to replace my rollers I noticed the rear pulley was harder then normal to compress. I took off the torque spring and found out ot was binding since all the grease was gone :oops: slapped in a spare rear pulley and the topend is back and some :rock: . Im liking the way this PG stuffed crank pulls. Although the malossi full metal one pulled harder.
GPS on flat ground tucked. Speed radar sign read 1mph higher :eyeroll:
Super Dio ZX "Ube"
72 corsa
sum_azn_kid
I tried 3 different drive faces. 2 sym/zx and 1 af16e all had play on the malossi splines. Heck even the ruima had a tighter fit :crazy: china crank better fit than Itialian....
Stock af16e, ruima and malossi cranks
And before people started saying it was a small spline crank :blah: I have a small spline af18e motor and the malossi crank is bigger... I learned my lesson always check new parts. I had this crank on my bench for about 1 year cant do anything with it now. Polini and PG FTW I would think for the price you pay for malossi stuff they would fit better. But Im not surpised their piston look like crap compared the the corsa's at least for Dio. I dont think Id use their parts for my jog project either. Dont want to risk or gamble my $ on it.
Super Dio ZX "Ube"
72 corsa
sum_azn_kid
Picked up some spare wheels
Finally got some chrome hubs
And brought an AF18e large crank motor back from my trip to Japan. Bought it for $20 :coolcruise:
Super Dio ZX "Ube"
72 corsa
sum_azn_kid
Super Dio ZX "Ube"
72 corsa
sum_azn_kid
Super Dio ZX "Ube"
72 corsa
harleyracer59
Post by harleyracer59 »
where did you get those solid wheels, and what is the hub bolt spacing???? ive been looking for a set of those in 2,10-2.75x 10 with a 141 pcd bolt pattern.. wanna sell those? my gyro and chopper spree will thank you.. lol :naughty:
sum_azn_kid
harleyracer59 wrote: Sun Jan 05, 2020 6:54 pm where did you get those solid wheels, and what is the hub bolt spacing???? ive been looking for a set of those in 2,10-2.75x 10 with a 141 pcd bolt pattern.. wanna sell those? my gyro and chopper spree will thank you.. lol :naughty:
Found in japan, I also made some friends there and they shipped it to me. Also there is a guy on Instagram from Philippines that can get them and chrome them. They are same PCD ad sym/kymco hubs I believe 4x140ish. And 2.50x10. TBH if it is for a gyro you maybe better off using atv wheels. Or having machined machines redrill a solid dwt wheel for you
Super Dio ZX "Ube"
72 corsa
harleyracer59
sum_azn_kid wrote: Mon Jan 13, 2020 12:09 am
its for the front of my gyro S I have 235/30-10 tires om 8" solid aluminum rims on the rear. I actually found a set on Y.A.J. 2.50X10" with 140 PCD bolt pattern. won the auction for 2 rims, 1 new tubless 90/90-10 tire. I think ill trow the second one on my chopper spree
edit: no clue why theyre upside down? I give up. you get the idea.... why is it so hard to post pics on this forum??? lol *? :*:
2 solid rims.jpg (463.14 KiB) Viewed 21943 times
image - Copy.jpg (123.2 KiB) Viewed 21943 times
