1986 nq50 hard to get started
- BMX
Re: 1986 nq50 hard to get started
That would be very nice just let me know wich one you think is the best and how much and I will do it..
and lastly other than premixed 80:1 for the first 2 tanks..
How does one properly break in new rings and piston??
1984 spree
1985 spree
1986 spree
1985 spree
1986 spree
- eclark5483
Now, THAT, is something many will have different opinions on. Some say to heat cycle it, some say ride only half speed, some say just slam it hard for a bit, then easy, then slam it some more. I mean there is no real proven method. On mine, I went the slam em hard route. I drove them from the bike shop to home. The bike shop is about 3 miles from my house and outside of town, so the first 2 or so miles, I had it at almost full throttle, from there, after I reached town, I went only about 20-25 (mine are high geared bikes). On a normal geared bike, this would be like going 12-20 tops. Then I let the bike cool down, then did 5 heat cycles. Ran the tank to almost empty with the 80:1, filled it with 1 more tank at 80:1, then on the 3rd tank, went to the normal mix. Has been solid ever since. Actually just got back from a nice after dinner ride on them with my son. I'll go get those cylinders and post some pics here in a bit.
- eclark5483
I marked them with a sharpie to indicate 1&2.
OK, here we have cylinder 1:
And this is cylinder 2:
And here they are side by side. 1 is on the left, and 2 is on the right
- eclark5483
I'm not sure what the significance is of the "B-6" stamped on cylinder 2.
- BMX
Sounds good I'll take both if you dont care I have another spree that I'm going to rebuild after this one and it will need the top end rebuilt too...
1984 spree
1985 spree
1986 spree
1985 spree
1986 spree
- BMX
Just let me know how much ... I really appreciate it..
1984 spree
1985 spree
1986 spree
1985 spree
1986 spree
- eclark5483
$20 for shipping will be fine, I'll send you a message with paypal info, please edit your post with your address and remove it for safety's sake so that it is not out there in the general public, thanks.
- eclark5483
Oh and after you get them, could you please post some images of those cleaned up ports and rehoning. Looks like cylinder 1 could probably use a bit of porting, I see a bit of rough edge on it. Not the worst, but porting is almost always a good thing.
- eclark5483
I noticed when I gave you the tracking number in private messages I skipped 4 numbers, but I see it arrived today. Sorry bout that, but at least you should have them now.
- BMX
Hi All,
So i Finally got my honda Rings this weekend (after waiting 3 weeks)..I cleaned up the cylinder which came out great all the rough edges on the exhaust port was just carbon build up it cleaned up real nice...I will add pictures tomorow i Left my phone at home.Once i got everything back togther i added a tank of 80:1 gas with GN2 oil and started it up , it fired right up i had to give it a little throttle to get it to start but once it ran for a min it idled great. i let it run for about 20 mins then shut it off. i let it cool down for about 3 hours Came back Had to give it throttle again to get it to start but once it was running it ran great and idled great. i took it around the block a couple times only doing about half throttle and the bike had great acceleration and throttle response(Way better than My best running spree i have,That i thought ran really good).
So First question is It normal to have to give it throttle to start after a fresh ring job ?? i don't see why it would be! My Iowa spree is the same way. And i have tried numerous bystarters and nothing seem to make it better once the scooter is warmed up it starts fine , from everything i have read on here that means the by starter is not working properly. Can anyone suggest where i should get a bystarter from or what else could be causing this?
Secound i have a wicked Vibration coming from the bike seems to be at all speeds and even while on the kick stand and you just rev it up ... don't thin it is the rear wheel feels like it is in the drive train or engine , i have checked the crank for play there is none. what elese could it be besides the clutch or the front drive pully?
Thanks eclark5483 For the cylinders and advice made this time around go alot smoother..
1984 spree
1985 spree
1986 spree
1985 spree
1986 spree
- eclark5483
That should improve after breaking it in. Gotta let the new rings seat a bit and that extra oil kind of throws off your fuel mix a bit. Wait till the break in is finished and you are back to a regular mix of just pump and gas and then see where you are at.
- eclark5483
Oh, and if you DO need another (86') bystarter, yep, got a spare one of those too.
- BMX
eclark5483 wrote: Mon Aug 19, 2019 2:27 pm That should improve after breaking it in. Gotta let the new rings seat a bit and that extra oil kind of throws off your fuel mix a bit. Wait till the break in is finished and you are back to a regular mix of just pump and gas and then see where you are at.
Awesome that was kind of what i thought but figured i would get some advise first before i start messing around with it..
I will keep ya posted...
1984 spree
1985 spree
1986 spree
1985 spree
1986 spree
- BMX
Ok So after some Crazy busy weeks i finally can give ya an update. After all is said and done the rebuild was a great success thanks to all the help eclark5483. after rebuilding the motor i found the cause for the wicked vibration the bearing in the tranmission cover was allowing in and out movement of the counter shaft. after chasing that for a week i finally have it running good enough to burn one tank of 80:1 mix. only to find out my kid filledx it up with straight gas. i think i caught it soon enough i think she only burn about half the tank .. so i drained it and filled back up with pre mix im going to run one more tank of premix and hopefully everything will be ok..While i was busy fixing this one up my other one stoped running like don't want to turn over. i knew something was up with that one because it was hard to get started without giving it gas just hadn't got around to it..
Ok so im gonna ask this question how do you know if the oil pump is working properly? beside just making sure the screen is clean and the gear is not worn out?
1984 spree
1985 spree
1986 spree
1985 spree
1986 spree
- eclark5483
The truth is.. don't worry about the pump. Does it still have teeth? Then yup its probably turning, relax. If anything, the $2.00 O ring in it is worn because of rubber's natural aging, duh.. And that might cause leaks and a we bit of performance that can't cheaply be measured, failing pumps are a myth, But, DO spend $2.00 plus shipping on a new ring.
