AF27 Dio oil tank as fuel tank?
kelamist
Post by kelamist »
Hey,
I have converted my AF27 Dio to premix. I am now thinking about deleting the fuel tank and instead using the existing oil tank (behind seat) as a fuel tank.
It seems like a pretty solid plastic tank, just wondering how it would hold up to having fuel stored in it? has anyone done this? Couldn't find anything related after a quick forum search.
Cheers
Re: AF27 Dio oil tank as fuel tank?
I did this on my SA50 Elite. The rubber fitting attached to the oil tank eventually deteriorated and leaked, gradually worsening over time. Plus you only get about a quart of capacity, at least on the SA model.
kelamist
Post by kelamist »
Cool, so sounds like the actual oil tank is fine just need to make sure the fuel line fittings are up to the task :)
Yes, polyethylene tanks will hold gasoline indefinitely - all the snowmobiles I've owned had 'em. Also my fuel cans are made of the stuff.
