Got my 86 spree up and running. Ran great for a couple weeks then died and wouldn’t start.
Zero compression.
So the question is. Swap the motor or rebuild top end? I was thinking I could rebuild but I don’t know the official cause so that technically could happen again.
Rebuild top end or replace motor?
Re: Rebuild top end or replace motor?
Find the problem..could be as simple as a $5 blown head gasket. Even a loose or broken head bolt, etc...DIAGNOSE IT before you make a decision.
