headlight and tail light won't work
Boomer
Post by Boomer »
started the spree up while checking it out the lights, both of them, just quit working. is there a fuse or fusable link that might have burned out or what? i am puzzled by this.
thanks
darat
Post by darat »
it is might be your stator that is your generator for the spree
Boomer
still puzzled
Post by Boomer »
so i take it that there is no other fuse or anything else i could check other than the stator? the spree runs well and when you put the brake on the light comes on. could there be a wire that is not connected somewhere on the headlight assembly? still puzzled by this headlight/taillight not being on while the spree is running.
vette76
Post by vette76 »
if the brake comes on then u might have a blown bulb but i would check all connections, and the ones behind the guages.
87' spree (SOLD
12' wrx
Boomer
Post by Boomer »
thanks i'll check those out. 'preciate the help.
