This may be a goofy question, but i just noticed i have 2 different exhausts from the same year. Obviously they may have been switched at some point from the past owners.
The numbers are gk80049 & gk80050. Quite a difference in size...is one an Iowa pipe? I did check the vin to see if one was an Iowa edition, they both have #60.
2 different exhausts, same year bikes
- 20200809_130747_800x685.jpg (518.54 KiB) Viewed 3503 times
- eclark5483
Re: 2 different exhausts, same year bikes
Top one, I believe, is from an 84-85' model year, bottom is from an 86-87' Neither are Iowa and neither are restricted.
Great, thank you for the information.
