87 elite se50/ dj1 50 clone
harleyracer59
Post by harleyracer59 »
wanted to put out some pics of the dj1 clone i just finished building.
got the scooter as a 30$ offerUp basketcase that had no plastics except speedometer and a chewed up wiring harness. only thing it had going for it was the motor wasnt seized.i strpped it completely down and cleaned and painted the frame gloss grey. i fitted a zx stem low down fork tubes. and painted aa set of zx wheels w? disk brake front. got a new jdm wiring harness, red and white plastics, white glove box, lights and dj1rr front clear corners. i had tp trim a little out of the right one to fit mastercylinder under plastics. then cut the brake lever off the same side. a switch back amber and white LED headlight and led bulbs everywhere else also. i stripped the engine cases down bare. ported the intake as much as i could. trench cut the cases, installed new c3 bearings and a stuffy crank from a kymco dj50. pinasco 47mm aluminum cylinder w/7 ports, pinasco head, keli overrange variator gy6 50 rear pulley with straight groove light weight clutch resd clutch springs and contra, 21mm mikuni flatslide carb stage 6 dio reed block intake with boyseen reeds. ebay expansion chamber modified to fit an af05e. 87 se50 10.00:1 gears
it came out pretty good. its quick. sits a lot different than my first generation aero's.
harleyracer59
Re: 87 elite se50/ dj1 50 clone
Here’s some more from bare frame painted and building.
harleyracer59
More.
harleyracer59
Here’s some more progress. I chopped off the brake handle on the right side so I can run a juice front brake and still use my oem switches. Swapped the yellow front turn signals for dj1rr clear lenses.
harleyracer59
More
harleyracer59
More
harleyracer59
More
harleyracer59
More
Good job on parts selection and assembly. How's it run?
Pellepan
Post by Pellepan »
Sounds interesting.
Is it just me or doesn't the attachment show? I can't see the photos.
Pellepan wrote: Mon Nov 28, 2022 3:57 am Sounds interesting.
It's not just you Pellepan.
During the 2 years of Covid, somehow it managed to infect our board, and many images were lost.
