Hey guys. I have an 86 spree with full tuneup. Plug air filter carb clean fuel line fuel filter new gas . Carb slide screw it’s adjusted and idle air screw is one and three-quarter turns out ... she idle well untill you hit the throttle. If your on the stand the throttle just pins like its stuck . When you use the brake It will come back down release the brake it will idle fine.. and no the throttle is not sticking. It relaxes and slides fine. And its not the clutch the engine rpms will
Not comeback down unless the brake is held.. any ideas??
Spree idle sticks
Spree idle sticks
1984 elite ch125
1985 spree nq50
1986 spree nq50
1987 helix cn250
1985 spree nq50
1986 spree nq50
1987 helix cn250
- vintagegarage
Re: Spree idle sticks
My guess is that your idle circuit is plugged up and you are idling on the main jet. When you screw in and out on the idle air bleed screw, does it have any effect on the idle speed? Does the engine stop when it's idling and you screw the air bleed screw lightly all the way in? If it doesn't, then your idle circuit is not being used.
It does affect the speed when i adjust the screw. The engine will die out or rev up
1984 elite ch125
1985 spree nq50
1986 spree nq50
1987 helix cn250
1985 spree nq50
1986 spree nq50
1987 helix cn250
My son just pushed it home after it died. Got alittle bit “jumpy”and died. I checkednspark and fuel which were fine and it started right back up for me..?
1984 elite ch125
1985 spree nq50
1986 spree nq50
1987 helix cn250
1985 spree nq50
1986 spree nq50
1987 helix cn250
Just a guess but it sounds like a vibration-dependent air leak. Check for it with a can of brake cleaner, sprayed on all the suspect spots. See if you have any seepage around the crank ends if the intake circuit checks out OK.
Yep i did try that too.. no leaks... it died again today.. compression is 150 psi.. changed vacum line and oil pump to manifold line . Oddly it ran well. Raced around WOT fine
1984 elite ch125
1985 spree nq50
1986 spree nq50
1987 helix cn250
1985 spree nq50
1986 spree nq50
1987 helix cn250
