Hey there,
I took a big break from my Nifty Fifty project but I'm back on I now, I've got it running nicely and painted and some trim and stuff all nicely squared away, HOWEVER, I"m still having issues with the electrics, mostly with the indicators, I've replaced the regulator rectifier which has helped, and I replaced the flasher unit this morning, now I'm getting the front right flashing nice and brightly, nothing on the rear and nothing at all on the left side, is there any common issues that might be causing this or am I looking at pulling apart the wiring harness and rebuilding it?
Thanks for any suggestions!
Cheers,
Your friendly Australian NQ50 Representative
Help with indicators
kingyachan
Re: Help with indicators
Alrighty, after more tinkering, it turns out it was the fittings, they were loose at every point so no solid connection, simple fix! I've got four fully functional indicators!
Good job finding the "fittings". Er, what are fittings?
kingyachan
like the bulb socket, sorry, fittings might be an Aussie thingWheelman-111 wrote: Tue Oct 05, 2021 10:20 pm Greetings:
Ah, mystery solved. Glad you're flashing .... um I mean Indicating.
