Honda Red - Spray Paint color
What’s the closest spray paint color for matching the oem Honda Red used on the Spree?
Re: Honda Red - Spray Paint color
Honda bikes are almost a pure red... fire engine red.
I had good results with Krylon Fusion "red" matching Spree and Elite SE50s... over 10 years ago. Current color is called Pepper Red and is probably same/close. Fusion stuck well to panels; make sure to prep them first per directions. I used a professional grade paint prep from autobody supply. YMMV.
Admin, Hondaspree.net
I found these colors a few years ago on motor scooter guide:
Sparkling Red (R127) - still available
From https://www.motorscooterguide.net/honda-spree-nq50/
Spree Colors:
1984: Sparkling Red (USA only), Cortina White, Vista Blue (Canada only)
1985: Sparkling Red, Black
1986: Sparkling Red, Black, Shasta White / Lollipop Green (only available on ‘Special’ version)
1987: Sparkling Red, Black, Kriti Blue
Spree Colors:
1983 Melody Deluxe II / ND50MC
1984 Melody Mini / NP50D
1979 Simson Schwalbe KR51/1 (think 2 wheel trabant/ East German Honda Cub)
Thanks! Went with Gloss Pepper Red from Krylon and it looks pretty close. Ended up repainting all the plastics in this color. Can’t attach pictures for whatever reason. Otherwise might be good for reference to have some posted with spray paint color.
All that said, if you use krylon gloss after, make sure the outside temps aren’t above 80 or you’ll get instant heavy orange peeling and have to redo it all.
Photo’s below of the new paint and emblems (brivander1 on ebay) for reference:
Looks Awesome!!!!Rideslikenacho wrote: Fri May 06, 2022 10:38 am Photo’s below of the new paint and emblems (brivander1 on ebay) for reference:
I'm just Brivander here though
1985 Black/Purple Spree-39 GPS
1985 Red/White Spree-40 GPS
1987 Black/Purple Elite-44 GPS
1985 Red/Black Aero-42 GPS
1992 Red/Gray Jog- 56 GPS
If you need a petcock cover I reproduce them as well, reach out to me here instead of eBay and I will sell to members here cheaper.
Looks great! Awesome job on the prep and paint; it shows.
Thanks, probably could have used a finer grit on a few spots before painting but I got lazy after having to sand off the clear coat and redo the top parts.
Now it just needs oem grips again (aftermarket sticks the throttle), petcock cover, would be great to get a floor mat but those are very hard to find, and a battery cover. If I had the software and machine/know how I’d just scan the other one I have and print the battery cover.
