Engine Stop Switch vs Turning Key
Oscarez14
Post by Oscarez14 »
So when I bought my spree the previous owner told me to try to never use the stop switch because you run the risk of messing your automatic starter up. Is there any truth to this? Is it better to use one over the other or are they the exact same and stop switch is just a commodity?
Re: Engine Stop Switch vs Turning Key
I believe you have been misinformed... :urban:
ntonar
Post by ntonar »
Why would Honda put a stop switch on the scooter if it messed up the starter?
Meatball
Post by Meatball »
About the only way the stop switch would mess up the starter is if you forget to switch it to “Run”. Then proceed to burn up the starter by trying to start it for 45 minutes.
Ive never cooked a starter by doing this but I have forgotten to flip the switch before.
