Well parts finally came today ……(crank seal)
I’m now trying to figure the best way to remove the crank nut w.o a impact wrench smh . Finding lotta dif methods and horror story’s online . Idk .unless anyone’s got a good enough fool proof way w.o a impact . I’ll be searching till I’m confident in the method I choose. .
Thanks for all the help so far folks , will keep updating .
Help with Spree please
Re: Help with Spree please
Also , got the new cdi ..,as a handful had suggested . Gonna swap this crank seal , clean and try one more time before I install cdi aswell. So none the less . I am hopeful the seal will solve the issue and I can get off the bus line to work b4 the cold really sets in . If it’s not the seal . I pray the new cdi will work and I’ll be Mobil again.
