Was wondering if I could make my brakes slightly better with some malossi pads or another aftermarket brand? If you can provide a link that would be rad.
Thanks,
Casper
AF16- Recommendations for aftermarket brake pads?
Caspervolas
- BMX
Re: AF16- Recommendations for aftermarket brake pads?
I had swapped for Malossi pads front and rear on Flash 7. I found them really grabby and a bit noisy. I eventually put the Honda stock pads back on the front, but I kept the Malossis astern. They do seem to brake harder with less lever effort, but the downside is a lockup in a panic stop situation. YMMV.
