AF05e with AF16 crank ?
braaaaapbrah
Post by braaaaapbrah »
I recently got a DD50 with a spree engine in it?
It’s a polini/malosi bore 72cc I’m pretty sure.
All the bored I’m finding for this motor is a curved exhuast ear but mine isn’t?
Bike hits 65-70mph (not sure how)
I was trying to send pictures with it but it says files too large.
Meatball
Re: AF05e with AF16 crank ?
Post by Meatball »
If it has a Polini/Malossi bore and it hits 65-70mph, I give you my personal guarantee, without a shadow of a doubt and with 100% certainty….it is not a Spree motor.
Easiest way I re-size pics to post them is use my iPhone to email them to myself. It will ask you what size you want to send the pics and choose Medium. Then you will get small enough pics to post.
IvyOperator
Post by IvyOperator »
braaaaapbrah wrote: Wed Dec 28, 2022 3:16 am I recently got a DD50 with a spree engine in it?
I know that the Spree and AF16 motor's have the same stud pattern for their bores. Can you show us the motor with the side cover popped off?
I do also know someone is looking into if the AF16 crank can fit into a spree. Complete game changer if it can.
1985 Spree
- Scooter Swap Shop Speed Pulley
- MLM People's Sidebleed Pipe
- Decked head
- Tuned stock carb
- Ebay cone filter
- SB50 intake and ceed cage
- Carbon fiber reeds
braaaaapbrah
Just found out my setup on my bike.
Installed a new polini corsa kit.
2AB mini stroker crank
AF16 short case
AF05 long block
Thank you all for trying to help
IvyOperator
braaaaapbrah wrote: Mon Jan 16, 2023 4:48 pm Just found out my setup on my bike.
AF16 short case
AF05 long block
Late reply, but can you post some pictures? I want to see this
1985 Spree
- Decked head
- Tuned stock carb
- Ebay cone filter
Meatball
Post by Meatball »
:bs:
sum_azn_kid
Post by sum_azn_kid »
Its probably an af16e or af18e with an af05e rear trans cover...
Super Dio ZX "Ube"
72 corsa
holddatfaka
Post by holddatfaka »
Meatball wrote: Fri May 12, 2023 7:01 pm:bs:
was previously running a 2AB but switch to a MHR stock stroke
holddatfaka
also someone said it was a variated af05e, which i believe it is
harleyracer59
Post by harleyracer59 »
sum_azn_kid wrote: Thu May 18, 2023 5:13 am Its probably an af16e or af18e with an af05e rear trans cover...
i think this is the correct answer to what engine is in this guys scooter. looking at that last pic he poste, 2 thingsverified that its for sure not a spree af05. 1, it has a 4 bolt reed block intake, spree engine only has a 2 bolt. 2. those case ports are 3x the size of spree engine.
which way does your kick starte does amr go? does it face backward or forward? from the shaft that comes out of the cover?
veedubh20
Post by veedubh20 »
:coolcruise:
