1998 Elite SR low top speed
O.McCormick
My Elite SR has been running fine but recently the top speed has lowered to 25 mph. I'll be at full throttle but once I hit 25 the rpms will drop and keep me at around 25 mph. I pretty regularly go on 30 and 35 speed limit roads so I would like to fix it soon.
Re: 1998 Elite SR low top speed
Hello,
This is what bothers me about speed limiters.
Inspect CVT components. Could be as simple as a worn belt or flat-spotted rollers. Maybe a new contra spring is needed.
Draw lines with a sharpie on the variator and do a top speed run. This will show you how high up the belt is getting at full tilt. Should be about 1/4” from the top.
If CVT checks out, do compression test and check entire system for air leaks: carb connections, intake, base and head gasket, crank seals, etc…
Could also be just a dirty carb or air filter.
Thet-thar's ^^ good advice fa sho'. Depending on mileage, another suspect would be the air filter. Pretty easy to check first. Worth changing a spark plug too. Another less-likely culprit is exhaust blockage. Including mileage and engine behavior - Stuttering? - when symptoms appear would guide advice more precisely. SR models had no speed limiters. Top speed = power + gearing minus wind and rolling resistance.
