Carb upgrade?
zz28zz
Carb upgrade?
Post by zz28zz »
I have a 1987 Elite 50 I bought from a kid abt 20 years ago. Got it running and then it got put away (long story). Bringing it back to life now. On the data plate it says it's a "SE50 P". However when I downloaded the manual, it says the carb I have is for a "SE50". The SE50 carb has a different part #, uses a larger main jet and the recommended idle mixture adj setting is different. Was this an "upgrade" by prev owner? Was the SE50 P a de-rated version (for Iowa maybe)??
Meatball
Re: Carb upgrade?
Post by Meatball »
The “P” was the restricted version. The non-P had a different exhaust, taller trans gears, and a different ramp plate. The carbs were the same except for a slightly bigger main jet. The speedo also showed up to 45 but could never quite get there in stock form without a big hill or gale force backwind.
If it were me, I would swap the ramp plate for one that has US2 stamped on it and call it good. That will get you better acceleration and a few clicks up top. The exhaust and gear upgrades are impossible to find, cost way too much if you do and the improvements are underwhelming.
FYI: the "US2" ramp plate sourced from a 1985 Honda NB50 Aero. Other years/models do not fit. Must be 85’.
zz28zz
Re: Carb upgrade?
Post by zz28zz »
Thx for the info. I suspect the prev owner may have swapped some parts out looking for better performance but it wasn't running when I bought it. Is there an easy way to tell if the exhaust is a "P" or "non-P" version?
Re: Carb upgrade?
zz28zz wrote: Sun Jul 09, 2023 2:28 pm Is there an easy way to tell if the exhaust is a "P" or "non-P" version?
Generally, a restricted pipe will have a smaller diameter head-pipe that maintains the same diameter the entire length, whereas the "hotter" pipe will have a stepped diameter from head to muffler. I can't speak with experience pertaining to the '87 Elite SE...even though i owned one before...lol...but as you see in the pic, this pipe is restricted. I think (maybe) the '87 SE was a model that only got the restricted pipe.
Elite e.jpg (82.21 KiB) Viewed 8654 times
zz28zz
Re: Carb upgrade?
Post by zz28zz »
Thx. Looks like I have the restrictive version but that's fine for my intended use.
