AF05 wiring help
Caspervolas
AF05 wiring help
Post by Caspervolas »
So i got a 1985 Honda spree that doesn’t run and I had a good AF05 motor laying around and it bolted right into the spree. I started wiring it and I can’t figure out where the 2 bigger green and red wires go. Everything else has a spot but there are no green and red wires on the motor.
Thanks,
Casper
Caspervolas
Re: AF05 wiring help
The swap I’m doing is a AF05 from a 88 Honda elite on a 1985 Honda spree.
Meatball
Post by Meatball »
What did they go to on the Spree motor? Green is ground and can be bolted anywhere.
Ive done this swap. Good luck getting the airbox to fit under the Spree panels.
