Honda Lead NH50
Alen
Honda Lead NH50
Post by Alen »
Hello,
I have bought this Honda Lead last week over here in Czech Republic.
I have done the registrations, bleed the oil pump, install a new battery and It seems that everything works great so far.
But... May I have few questions 🙏
1. I dont really know what bike it is and what kind of parts ll fit on it. In paperworks there is written Lead NH50 AF01 (AF15).
So I assume that parts from Dio AF16 wont fit.
2. Scooter needs a new pipe. I wonder if i can fit Dio Tecnigas pipe if reweld it a little. What do you think?
3. If i do some mods I believe that I ll have to adjust oil pump somehow. Yes?
4. And last question is that im missing metal shrouds around cylinder... Do i really need it? Can i ride without it?
Thank you for any help 😁
Regards from Prague
Alen
Re: Honda Lead NH50
Post by Alen »
Code: Select all
https://allegro.cz/nabidka/vyfuk-tecnigas-next-r-honda-dio-kymco-zx-dj-dy-13644278175
Code: Select all
https://www.proskutry.cz/p/valec-wm-d-48-litina-sport-72cc-pro-honda-lead-50-sh-50-peugeot-sc-metropolis/
Few things i wonder to fit to it
Alen
Re: Honda Lead NH50
Post by Alen »
I have bought af18e engine. Is there any info how to mount it?
Alen
Re: Honda Lead NH50
Post by Alen »
Alen
Re: Honda Lead NH50
Post by Alen »
bonesv
Re: Honda Lead NH50
Post by bonesv »
Bud, you've got to make a special adapter to get that to work properly. Those cases are aluminum so I would really sit down and draw up a plan so that mount that will do the job you are gonna ask it to do. It might be easier than I think it will be but I know it has probably been done before. Good luck with that!
Re: Honda Lead NH50
Alen wrote: Sun Oct 22, 2023 3:38 pm I have bought af18e engine. Is there any info how to mount it?
No info available as far as I know.
You are in the region of untested waters.
Plenty of engine swaps have been done,
but your particular situation and model are not known in the USA.
Alen
Re: Honda Lead NH50
Post by Alen »
Thank you guys for response. I took old engine out and it doesnt look too bad.
Only bad thing is a wheel. Ill have to use Dio rear wheel and not the "rotary" wheels from NH. There is different offset and also NH wheel has thicker midle section and than there are almost no threads left.
And the engine... ill have to use Dio shock and make some engine mount. I tied to make one from original Dios mount but it hits the frame.
Before i mount the engine i want to order some tecnigas exhasut so i could move engine back if it d be needed. Here are some pics
Alen
Re: Honda Lead NH50
Post by Alen »
Alen
Re: Honda Lead NH50
Post by Alen »
Alen
Re: Honda Lead NH50
Post by Alen »
Here is the wheel I canot use hehe
Alen
Re: Honda Lead NH50
Post by Alen »
Small update
Engine mount is done but not finished yet
Pipe has arrived but rewelding was necessary to fit it under plastics
Here are pics
Alen
Re: Honda Lead NH50
Post by Alen »
It fits without cutting the plastics
Alen
Re: Honda Lead NH50
Post by Alen »
Guys, dont you have recommendation for big bore kit please.
That pipe should be fine for 70cc kit. But to be honest those 120cc kits from twh are pretty appealing.
But over here i can choose from Polini Contesa/Corsa, Malossi and aluminium Athena.
Malossi is cheapest from these.
And also i have bought CT intake and fake 19mm PHBG.
Alen
Re: Honda Lead NH50
Post by Alen »
Well, I dont have a spark. I have kept old wiring, coil, cdi and connect engine wires with rest by colours.
Ill have to look to the manual and compare these two scooters.
