1987 elite SE50P
roaddog
1987 elite SE50P
Post by roaddog »
I just picked up a 1987 SE50P, but there is no air box and i'm looking to find what i can replace it with.
Does anyone have one that they would sell or does anyone know if the SB50 or SA50 air box will fit?
thank for any help
Re: 1987 elite SE50P
Congrats on finding this Rare Bird. I think the '87 box was unique to that model. Nearly certain the SB won't fit, but the SA might be adaptable. The other option is a cone filter and appropriate jetting change.
roaddog
Post by roaddog »
what would be the right size jet to use with the cone filter?
I'd start with a 92. Check temp gauge if you have one or read the spark plug after a few miles.
bonesv
Post by bonesv »
Maybe buy a small, 5-jet kit to have to tune with. I think the best one to try to find would have like a #85, #88, #90, #92 & a #95 in it, or buy them individually? Try Scooterswapshop.com I think they carry those. Start high (#92) and work down is best so you don't run it lean. Keep in mind that the stock carburetor on your scooter does not have a changable pilot jet so you will want to lower your needle jet clip on the end of the throttle cable to ensure as much fuel supply to the closed throttle after a wide open throttle run. Look thru these pages for more info about it.
roaddog
Post by roaddog »
i will be ordering that kit and will get back with my progress
thanks for the help
Meatball
Post by Meatball »
Meatball
Post by Meatball »
Get ahold of this guy. Have him sell you the exhaust and the transmission gears.
https://portland.craigslist.org/wsc/mpo ... 19820.html
Meatball
Post by Meatball »
Then buy this and youre set. With this variator, the unrestricted exhaust and the 10:1 gears installed you’ll have good acceleration and a top speed around 45.
https://www.ebay.com/itm/204802261482?i ... R7zPn9mIZA
Meatball
Post by Meatball »
Need to upjet slightly with that new exhaust. I believe the stock main jet is 78 or 82, cant remember exactly. Bump it up to 88-90 range and she’ll sing.
roaddog
Post by roaddog »
talked with the guy that i picked this up from and he was able to find the air box so now i'll be ordering an air filter from noiseguy.
will maybe look at doing some other things after i've had a chance to see how it rides.
thanks for all the help
Meatball
Post by Meatball »
The unrestricted exhaust and 10:1 gears for the 87’ are unicorns. Jump on those because you might never see them again.
