Broken case: gearbox bushing / sleeper build questions
2tkwik
Post by 2tkwik »
I have everything I need to fix this gearbox issue, however, I would some help on which route to take, and I would like to switch up my build. Sorry if the two questions in one thing is against the rules.
https://imgur.com/a/8Y12WSu
https://imgur.com/a/LapPIr7
(Hopefully these pictures work)
I have a spare stock motor, however, I would like to get away with having 2 motors at the end of this.
My options are:
1. Put a new gear, bearings, and cover on old af16, and send it, I have a new motor if it breaks
2. Run stock motor bottom end for now, try to get old motor bushing sleeved at machine shop (or of one of y’all can do it)
3. Swap cases
My build:
polini corsa
arrow pipe
malossi crank
26mm pwk
Polini ruckus variator
Stage 6 clutch
zx trans
Planning on using 9:1 gears
I would like to make my scooter as quiet as I can get it, while being able to go in the mid 50s with plenty torque. I was thinking about swapping pipes and getting some sort of airbox setup.
What is a good quiet exhaust for my build?
Where can I buy one of those pwk dio air boxes, and would I need a smaller carb due to the exhaust?
Would my transmission setup need to be changed?
Will be updating y’all on the repair or build.
Re: Broken case: gearbox bushing / sleeper build questions
I've always thought you could have those case interfaces bored and resleeved. But I've never looked into having it done.
bonesv
Post by bonesv »
"Will be updating y’all on the repair or build."
Please do this. It will help us to find out.
First thing you need to do is find out why it did this? That is not normal wear and something is incorrect for it to do that kind of wear. Either a washer is missing, or the gear was pressed on incorrectly or you used incorrect parts? Do you have any pics of the complete setup like it was when it ran? Show all of your parts so we can see if anything looks suspect. What is your parts source for all of these aftermarket parts? Who did the installation of these parts? Were all the parts from the original motor? Please answer these simple questions for us. :mrgreen:
By the way, which gears did you decide to run? :popcorn:
