starter just clicks
dojo
starter just clicks
Post by dojo »
got power, got lights, got signal lights, no starter motor going... my starter relay just sits and clicks everytime i brake+start button any suggestions? thx :)
vette76
Post by vette76 »
try bypassing the switch if it turns over u need a new relay. if it doesnt it could be the starter. make sure it isnt hung up and the batt. isnt dead.
87' spree (SOLD
12' wrx
burnt_toast
Post by burnt_toast »
jump it (just dont turn the car on when jumping).
what ur describing sometimes happens when the battery is too weak. if jumping it gets it going, then uve found ur problem, if it doesnt then its something wrong with ur alternator.
projects galore :nerd:
dojo
Post by dojo »
well what i noticed is if i bypass it, the starter motor will run for about 4 seconds and start fast and slowly die, to the point of a crawl, and i cant really jump it and take it for a ride to recharge the battery quite yet. still working on getting it going =/ new sparkplug, clean carb, clean filter, spark, gas, no fire.
vette76
Post by vette76 »
just take abatt charger and crank it over with the charger on.
87' spree (SOLD
12' wrx
burnt_toast
vette76 wrote:just take abatt charger and crank it over with the charger on.
DO NOT DO THIS!!!
sorry vette, but this is very bad advice. trying to start when the charger is still hooked up to the battery can cause serious problems, like exploding the battery! i tried doing this once and it almost ruined my electrical system and blew a fuse.
charge ur battery overnight and then put it in and see what happens.
vette76
Post by vette76 »
i have never heard of that happening unless it is hooked up to a car or something with to many amps. i always keep the charger on 2 amps.compared to the 200 that it will go up to.
87' spree (SOLD
12' wrx
burnt_toast
vette76 wrote:i have never heard of that happening unless it is hooked up to a car or something with to many amps. i always keep the charger on 2 amps.compared to the 200 that it will go up to.
well in my case, the charger was at a higher ampage, which would be like trying to jump it from a car that was running. but if its at a low amps then u should be ok. id still just charge it overnight though, just for safety.
